Good grief Bonnie. Yea, I think you guys are going to be the SLAM time frame winners at this rate for sure. I keep running everything we've done over and over trying to figure out what the heck is still causing the problem. If it's algae still, where the heck could it be hiding we have had you guys turn that pool upside down already. It's possible because of the pool RX that it could be algae and metals both causing the problem?
I personally know nothing about the Pool Rx, but I'll do some research on them, and ask around to see what I can find out. Of course here we recommend not using things that will add any unwanted or unnecessary things to your pool including copper, because it can make you have more issues because of that. Bleach, borax, baking soda or acid is usually all it takes to keep your pool clean, balanced, and properly maintained.
I was talking with another member earlier today about the difficulty your guys have had and as soon as it looks like the numbers are starting to stabilize, and like you might finally be getting close to being able to pass OCLT then Bam here you go again. Is there anything around your yard, your neighbor's yard, factories close by, ( lol crop dusters flying overhead lol you can tell I'm from KY
), or anything that you know of that could be emitting things into the air or anything? Also we were even discussing the citrus tree, and I'm going to question that with our Experts too, as who knows, perhaps the citrus tree are emitting citric acid somehow into the pool causing the continuous backslides, but something is going on that isn't being found or killed out or something and we've got to locate it. About how close is the citrus trees to your pool?
Another thing I want you guys to do if you don't mind is to clean out your vacuum, and the vac hose really well with the garden hose, and see if you get anything out of it. Then again check/clean behind the light, recheck the skimmers, the lines, the returns, anything that allows any water, chemicals, or anything back into the pool, or anything that could possibly be harboring algae. I going to ask some of Experts to get involved with us here too, to see if they can find what we're missing so we can hopefully get you fine folks cleared out. I really thought after the supply cleaning and the Fc drop, and CC rise that once that ran it's course that would finally be the end of it, but nope, I guess not because the numbers again tell us otherwise.
Would it be possible for you all to take a water sample to the pool store, and have it tested for metals to see what it is now showing? It could be possible I suppose that you might need to add some kind of sequestrate to resolve this issue, but a test for metals will help us determine what may or may not be needed. Anyway, I'm sorry that the numbers did it again on your guys. I'll try to get some Expert's advice on this to try to get this resolved because apparently we are still missing something somewhere, be it algae, metals, both, or ?, and it appears that Slamming alone isn't taking care of it, and it's just going to continue to keep causing you problems over and over again.. So, if you all will get a water sample checked for metals to see where they are now, I'll be working on the my end, and we will go from there. Have a wonderful night
