Thread: RObots and sun ledges
    Sep 2015
    Bluffton, SC
    1
    New pool owner in SC with a 5' wide sun ledge which is about 5 " deep. Are there any cleaning robots which can climb up a wall / steps to reach and then clean a sun ledge at that depth or which could be started on the sun ledge before going to deeper water?? thanks for any suggestions.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,013
    Re: RObots and sun ledges
    Hi Scotty,
    There might be some that will climp up on it, but depending on how big it is will determine a lof in how well it will work, if at all.
    the robots need a bit of room to maneuver around and so they generally end up fallong off the shelf.
    Divin Dave,
