Thread: any opinions on the jandy plus hp pump?
    Im replacing my 1 HP pump and 1.5 booster pump with a single two speed pump. Does anyone have an opinion on the Jandy PlusHP? I'm looking at the PHPM2.0-2 model. I found it for $460 and my electric company offers a $200 rebate. Will that make a good pump for this situation? I havnt been able to find any online reviews.
    15,000 gallon gunite pool, grey plaster with 8' raised spa
    Jandy PlusHP Pump 2 HP Dual Speed
    Sta-Rite 450 Sq. ft. Cartridge Filter
    Cleva-Chlor RP40HD
    Raypak 400k btu heater
    Jandy Aqualink RS-8 One Touch
    Savi Melody 12v LED lights
    Guest
    Re: any opinions on the jandy plus hp pump?
    Quote Originally Posted by n8scstm
    1.5 booster pump
    Do you mean a .5 hp booster pump (for a pressure side cleaner)? If so realize that the purpose of a booster pump is to provide high velocity (water pressure) but not move a lot of water at a time so replacing the two pumps with a singe pump might not be successful.
    No, it's a 1.5HP booster,although there may be a better term for it. I bought the system used, fully plumbed. He told me it was a booster to the spa. By the plumbing, it looks like the 1 hp filter pump discharge goes to a valve. One side goes to the pool and the other must go to a floor heating jet in the spa. The second 1.5 HP "booster pump" looks as if it just works the jets. There are no valves, or anything. Just an inlet and an outlet. My pool is considerably smaller than the pool in which the system came out of too. 17,000 gl vs. roughly 25,000 gl.
    The Booseter pump is the one on the right.
    Cleva-Chlor RP40HD
