Thread: Solar Cover - Blue or Clear?
    Sep 2015
    Albany NY
    18
    The clear solar covers I see online claim to produce more heat, which makes sense because the sun penetrates better than blue. But does that mean the sunlight will eat more chlorine when using a clear liner as opposed to a blue liner? Will a blue liner protect the pool better? Or is this a non-issue when your CYA levels are within range?
    Mike
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: Solar Cover - Blue or Clear?
    There are a lot of threads out there, see ChemGeek's in particular or the one below. From what I gather, here is the consensus.
    Clear = more heat production
    Blue = more sun protection and less FC loss
    UV rays will destroy active, unbound FC at any CYA
    Best color for solar cover? And thickness? And....
    It is worth noting that a solar cover is more effective at retaining heat than creating it. Meaning there is significant benefit in using any cover, especially at night or when windy, regardless of color and that a pool seems to heat more sans any cover when in the sun.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
