Results 1 to 8 of 8
Thread: I give up. White Flag.
    TinaJ718's Avatar
    Jun 2013
    Minnesota
    18
    Thumbs up I give up. White Flag.
    OMG!! This year I swear I cannot catch a break... between green, murky water and hoses not staying connected, to hoses cracking in the middle of the night and draining the pool down to the skimmer, to needing a new liner and having to trim decking boards... I want to give up and throw in the towel. I hate, hate, hate, hate this pool!!! I am seriously considering ripping the whole thing up and burning the deck around it!!!!!! AAAAAAAAAAAAAAAAAAAAGGGGGGGGGGGGGGGGHHHHHHHHHHHHHHHHH!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!
    SO Frustrating!!!!!!
    24 ft R, Niagara by Asahi Pools, ABG, 13500 gallon, hayward 1hp single speed pump, swim pro sand filter.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    Re: I give up. White Flag.
    Welcome to the place you've been waiting all season for.
    We will have you loving your pool very soon.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jun 2014
    15,189
    Your season is almost over. Time for a well-severed break. Start-up fresh next year and we'll be here to try and help. In the meantime, if you need some winter preparation guidance, just let us know.
    TinaJ718's Avatar
    Jun 2013
    Minnesota
    18
    Thank you... Sorry. Just frustrating. Any suggestions for a pool level alarm (that doesn't have to be connected to a hose!?) I am google searching as I type.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Hi Tina,
    I dont know if there is a water level alarm available, but have you considered hard plumbing all of the pipes?
    I can tell ya, hoses will always eventually fail. It's not hard to do and is relatively inexpensive at probably less than 50 dollars in materials. In the long run, will solve the problems of hoses springing leaks.
    just a thought....
    Divin Dave,
    TinaJ718's Avatar
    Jun 2013
    Minnesota
    18
    Great suggestion, I'll have to research a bit, since I am in MN and everything freezes, I suppose if I drain and leave open it wouldn't be a problem. Thanks, I'll look into it.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I would hard plumb the lines with rigid PVC next spring. It will save many headaches over the life of the pool. Materials are cheap and with some practice, most anyone can do a good job. All that's needed for winterizing hard plumbed piping is to blow out all the water from the lines and add some RV antifreeze to the lines as insurance from expansion cracking. Then blow out antifreeze before starting up in spring.
    If you're close enough, I might even consider giving you a hand...
    Isolated Spa - 345 Gallons
    May 2012
    Montville NJ
    545
    I see you have an ABG, if you do you plumbing correctly, you don't even need to blow out lines or fill them with anti freeze. As along as they don't have any dips in them where water can collect, they are self draining.
    I have unions on mine right next to my pump/filter. I plug the skimmer and return, remove the pump and filter and put it in the shed, cover the pool, and I am winterized. It freezes in NJ too
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
