Results 1 to 14 of 14
Thread: Help. Help. Help.
    trncbill's Avatar
    May 2015
    Nicosia Cyprus
    15
    Help. Help. Help.
    Hi. Well it's been a while since i was on here. And with you guy's help our pool has been fantastic. And here i am again on the best site for pool probs. But due to doing lots of of repair work around the bungalow. I tool my eye off the pool for a couple of day's and Bingo. The pool is now green and cloudy. We had some very heavy winds that blew lots of leaves and debris into the pool. I have Backwashed to waste but pool still green and cloudy. Added 1/2 bottle of Zerochlor
    Zerochlor Home Page
    It has helped a bit. But now think the filter is now blocked. I turned off all valves in the pump room and loosened the nuts on top of the filter. "See pic" But stopped as water was coming out, The question is how much water is in the filter? Do i just loosen the top and let the water run out? Bit worried as i don't want to flood the pump room.
    Many thanks. Bill.
    We have a in ground 10 x 5 Overflow Pool. All tiled in pale blue with dark blue at the top. In the pump room is the usual sand tank with a multifunctional thingy and a pump filter and timer.
    Bill.
    Jun 2014
    15,274
    Re: Help. Help. Help.
    Bill, it's hard to tell from your pic, but you should have some 2 or 3-way valves before/after your pump that would isolate water flow from the pool to the pump. That way, when you loosen and remove the top portion of your filter, only the water from within the filter will spill-out. The closed valves should prevent water from flowing back to the filter from the pool.
    As for the green, that's another story. That sounds like algae in which case you would need to "SLAM" via Pool School - SLAM - Shock Level And Maintain.
    trncbill's Avatar
    May 2015
    Nicosia Cyprus
    15
    Hi. Thanks for your reply Can't see any valves either side of the filter. "See Pics" Filter side 1.jpg Filter side 2.jpg But surely if i turn off all the valves it will only be the water in the filter will come out. Will it not? What do you think.
    Regards. Bill.
    Bill.
    domct203's Avatar
    Jun 2015
    CT
    3,597
    Quote Originally Posted by trncbill View Post
    Zerochlor Home Page
    Many thanks. Bill.
    Hello!
    As mentioned, you should have valves on the pipes that run between the pool & pump, and between the filter & pool. Close those valves. Be sure to open them before you turn on the pump!
    Why did you turn to the Zerochlor? What were you attempting that Bleach/Chlorine could not do for you?
    There are some rather interesting statements on the Zerochlor website, that's for sure......
    Quote Originally Posted by zerochlor
    When you dose chlorine into a pool, the chlorine breaks up into two components, chlorine gas and chlorine salts. The chlorine gas is the dis-infection agent while the salt is a by-product and nuisance in the filter. It usually gradually blocks the sand filter.
    WOW! How the heck are all these SWG pool owners with sand filters getting by?? If the insignificant amount of salt in liquid chlorine blocks a sand filter, these SWG's must be turning them into bricks!
    Normally the chlorine gas is volatile it will stay active in the pool for approximately 20 minutes. There after there is no or very little residual effect on the swimming pool water. Because of the volatility of the product it will have an even shorter active life span at higher temperatures. Any contamination of any kind that enters the facility after the twenty minutes will go untreated until the next dosing of the pool.
    Interesting that every time I open a new bottle of chlorine and add chlorine to the pool I check my FC level 30-40 minutes later. Never has it been zero, NEVER.
    If I was you, I would stay clear of that stuff. I can't find an MSDS for it & have no idea what the ingredients may be, and the statements on their website do not relate to the real-world experiences I (and others) have with a chlorine pool.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    trncbill's Avatar
    May 2015
    Nicosia Cyprus
    15
    Hi. I was told by a friend to use Zerochlor by a friend as a quick fix. Will not go there again though. In the pump room there are Waste. Hoover. Main Drain. Inlet. & Balance/Check Valves. The Balance/Check Valve is to draw water from the balance tank. We do not have mains water here. We get our water from Water Tanker Trucks. And we fill the Balance Tank to draw water for the overflow system. So do you think if i close all the valves the only water that will run out is from the filter itself, surely there can't be a lot of water in there.
    Many Thanks.
    Bill.
    Bill.
    domct203's Avatar
    Jun 2015
    CT
    3,597
    Many Thanks.
    Bill.
    Can you post more pictures of your equipment? I'm not comfortable just telling you to start turning all the valves.
    I am hoping that there is a valve just before your pump (or filter), & a valve right after the filter.
    Dom
    Dom - TFP Guide
    trncbill's Avatar
    May 2015
    Nicosia Cyprus
    15
    Hi again. OK Balance. Hoover & Main Drain valves all link into front of pump. Inlet valve links into multi function pipe from top of pump also links in to multi function. Waste pipe comes from back of multi function. The pump and filter is a Odina Ondina Kripsol swimming pool pump | Kripsol Rudy-shop.eu This pump is the same as ours.
    And i can't find a air release valve. (The Balance Valve is used to draw water from a balance tank (Storage Tank) to use the pool on overflow as we do not have mains water here)
    Waste Pipe Hoover Balance & Main Drain Inlet & Main Drain Valves
    Hope this helps. Thank You.
    Bill.
    Jun 2014
    Gulfport, MS
    67
    nm....you posted pictures before I posted...
    17K gal, AG, 1.0HP pump, 300lb, 3.14 sqft, 62GPM sand filter, Pool Pilot Nano SWG, TF-100 Test Kit
    domct203's Avatar
    Jun 2015
    CT
    3,597
    Are these the balance & main drain (lower pipe) and waste, with the balance (lower left valve) closed? It's hard to read the labels in such small pictures.
    Is this the return to the pool, and if so, is it the only return?
    Can you take one more pic, with all the plumbing in the pic?
    Dom
    Dom - TFP Guide
    trncbill's Avatar
    May 2015
    Nicosia Cyprus
    15
    Hi All. OK got the top off the filter and all is OK. So got a bit annoyed with myself and chucked a load of Chlorine in the pool last night just as it got dark. And this morning the pool is almost clear. Topped up the pool as well. CL is high but the new water will clear some of that. PH is also high so will add some acid top bring it down. So thanks again for your help. Will now keep a very close eye on the pool now. It is going too hit hit 40C over the weekend here so will nice to get in the pool and cool off.
    So lesson learned, look after the pool even if you are busy with other jobs.
    Thanks again.
    Bill.
    Bill.
    Jun 2014
    15,274
    Glad to hear it all worked out Bill. And say, as a reminder ,.... since you hit the pool heavy with chlorine, be careful about the pH. When the FC is over 10 the pH will naturally read high as well until the pH drops back down. Just a thought. Have a great day.
    trncbill's Avatar
    May 2015
    Nicosia Cyprus
    15
    Quote Originally Posted by Texas Splash View Post
    Hi Texas Splash.
    I will now be really careful on chems, readings, and filters etc etc. Thanks. and you have a great day also.
    Cheers.
    Bill.
    Bill.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    If you had algae or cloudy water, you might want to Pool School - SLAM - Shock Level And Maintain perform a SLAM, or at least bump your FC and perform an Pool School - Perform the Overnight FC Loss Test (OCLT) OCLT.
    How are you testing?
    trncbill's Avatar
    May 2015
    Nicosia Cyprus
    15
    Hi All. Sorry to bother you all again. OK Readings. See Pic. Readings.jpg I know the CL is high as i shocked the pool on Wednesday evening. The Algae is now all gone. Now am i being to impatient here, as the pool is is a milky cloudy, can see the bottom at the deep end but just a bit cloudy. Do i need to adjust the Acid levels. to combat the high CL. Or do i just relax and let the chems do there job. Last night i hoovered to waste, And just back washed about 1 hour ago.
    Regards.
    Bill.
    Bill.
