Hey guys. I've got a slime bag attached to the return right now. Problem is that there's no circulation with it in there. It just return the water to the surface right next to the skimmer. So I'd think it's just sucking in the same water it just filtered? The other problem is that with our solar heater all the warm water is just floating on the top 6" of the pool. So the controllers seeing 91 degrees but the 42 or so inches below that is 78 degrees. We're not in the pool everyday so swimmers aren't circulating the water either.
So...I was considering making a 90 degree "L" right off the return and relocating the slime bag to the bottom of the pool. Would that work? Any other suggestions?
