Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Just got my TF100 test kit
    Aug 2015
    Greenwood Lake , ny
    27
    Just got my kit UPS ground. Came pretty quick. Only order it Friday.
    Okay. Here is where I stand. Pool is cloudy but I can see the bottom in low end can't make out the bottom on Deep end. There is yellow brown algae on the bottom of the pool going down to deep were I can see. I vacuumed up the low end Sunday. Any help greatly appreciated. Haven't been able to use pool for last 5-6 weeks. Some numbers:
    PH-7.2
    FC-13
    Total Alkalinity-60
    CYA-70
    30,000 gal inground, vinyl, Hayward sand filter, 1 hp pump, Well water make up, Raypak heater w/bypass, TF100 testing kit.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Just got my TF100 test kit
    Congrats on the new kit!
    Time for you to Pool School - SLAM - Shock Level And Maintain
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    Hi Oscar,
    Ok, not as bad as it could be. Its workable.
    pH is OK for now, TA is OK, CYA his higher than we like but its workable.
    You need to SLAM the Pool. What that means is raise the FC to what we call SLAM (similar to shock), but only using liquid chlorine (a.k.a. bleach). Using any other form of stabilized chlorine will make your CYA get even higher, and that is not what you need.
    The more often you can test, meaning multiple times a day, and replenish the chlorine, the quicker it will go. The first couple or 3 days are the most important.
    You also need to brush the pool daily. Get that algae stirred up so the chlorine can get to it and kill it. If you dont brush, its gonna take a lot longer to kill it all.
    With your CYA level of 70, your SLAM FC level is 28.
    Do all you can to not let the FC drop below 28.
    So, you need to raise your FC to 28, or slightly above, and MAINTAIN that FC level until
    no more visible algae.
    your CC is .5 or less
    you pass the overnight chlorine loss test.
    Do you know how to use pool math? This and your test kit will be your best friend.
    http://www.troublefreepool.com/calc.html
    top left, enter your 30K gallons
    In the FC row - box on left, enter your FC test result
    The box to the righ of that, enter your "goal", in your case, 28.
    then click the calculate button. (no need to do any of the other parameters until you get your algae taken care of.).
    Getting rid of the algae is a process, not a 1 time thing. It might take a week or longer to get you fixed up, but if you stay with it, you will get rid of the algae and have the clearest water you've ever had.
    Quote Originally Posted by Oscar477 View Post
    PH-7.2
    FC-13
    Total Alkalinity-60
    CYA-70
    Divin Dave,
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Stock up on bleach, you are going to need a lot of it, many, many gallons!
    chiefwej
    Aug 2015
    Greenwood Lake , ny
    27
    My wife got 10 gals of bleach at hardware store. Checked it online and it's only 3%. Have to bring it back. Going to a pool store in the morning that has liquid Chorine. OH Boy!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,616
    Oscar you might be better off with bleach from Walmart unless the pool store is super easy to get to. You are doing to need quite a few gallons to beat the algae monster.
    Can you take and share a pic with us please?
    Kim
    Aug 2015
    Greenwood Lake , ny
    27
    • image.jpg (41.9 KB)
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Also... next time you're shopping for bleach use this formula: Price / ounces / percentage as a decimal = price per hypochlorite. Example: $3.00 / 128 ounces / 0.0825 (for 8.25% bleach) = $0.28 The lower this number is, the better. A good deal is anything around $0.20. It doesn't matter where you get the bleach or what the concentration is, it's that number that matters. And that it's fresh. Bleach degrades over time so check dates on bottles to see when they were made. Convenience factor of higher % bleach also comes into play for lugging jugs around and recycling.
    Pool doesn't look too bad. Some cloudiness and definitely not that TFP sparkle... YET! Hopefully it's a quick SLAM process but have some patience and it will go fine.
    Isolated Spa - 345 Gallons
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    that's not too bad Oscar. SLAM will get that pool in shape nicely. if you can remove the ladder, I would do that. Also, any lights should be removed from the niche
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Aug 2015
    Greenwood Lake , ny
    27
    Photo is after just vacuumed. Numbers have not changed. Just did test.
    PH-7.2
    FC-13 ( I would have thought it should have gone down since I havn't add chlorine.
    TA-60
    CYA-70
    Took Bleach back to Hardware store. They tell us they sell HtH liquid Chlorine 4 gals for $15.00. Should I use this?
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    well your FC level should be 28 based on the CYA/FC chart since you are SLAMing the pool. you need to test as often as you can, the goal is to keep your FC at 28 the entire time. you can go a few ppm higher to help give you some wiggle room between tests.
    that's $3.75 a gallon. is it 10% or 8.25%?
    can you remove the ladder and lights?
    Dan
    Aug 2015
    Greenwood Lake , ny
    27
    Danin. Thanks for the replies
    It's 10% and Yes to the ladder I think but no with the fiber optic lights. Another problem I have is raising the FC to 28 as we are surposed to have an end of summer party Sunday. Will it be safe to swim in? Is it safe right now? Also pool is scheduled to be closed next week. Wish I would have found this site at the beginning of the summer!
    Feb 2014
    Central Minnesota
    5,080
    At 10%, that's $0.28/hypochlorite. Not a good deal, but it will work. Check on pricing of 8.25% at a local big box or grocery store. Use that formula to check if it's cheaper (and fresh).
    It is safe to swim at any FC up to the shock level for your CYA. It will be a bit more harsh on you suits and hair, but safe if you can also clearly see the bottom.
    sent from mobile. beware of brevity and spelling errors.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    if your pool is as cloudy still as the picture looks, then no, its not safe. so many stories over the past couple of years with people drowning in pools because they could be clearly seen. not worth it. hit that pool really hard, you have 3 days you might be ok. but you are going to have to be very diligent in your testing and adding of chlorine. as far as safe to swim chemistry wise, yes it is. just let your FC fall below the shock level before the party...if the pool has cleared.
    just curious, why cant you remove the lights?
    Dan
    May 2015
    Moorpark, CA
    171
    Quote Originally Posted by DaninFLA View Post
    Probably a newbie question, but you are supposed to remove the ladder and lights during a SLAM? Does the chlorine react with the metal and corrode it? I didn't see this in Pool School.
    Michael
    20,000 gallon in-ground gunite/plaster pool (1992), attached spa with spillway, Pentair Superflo 1.5 HP pump, Smith booster pump for pool sweep, Pentair 2000 DE filter, Sta Rite Max-E-Therm 400 heater, Silencer Blower 2 HP for spa, Polaris 280 pool sweep.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    No you just want to make sure there is no algae hiding behind lights, on the bottom of ladder steps or inside the ladder tubes.
    chiefwej
    Aug 2014
    Northern IL
    4,615
    Also, next time you buy "bleach" or "liquid chlorine" (same chemical) check for freshness by looking for a 5 digit code like 15240. That means it was bottled on the 240th day of 2015. Even at the same store, check that number!
    If you can postpone closing until the water temperature is holding at 60 degrees or below, it will really help your odds of opening clear in Spring. That would also give you the time you need to fix everything now. Just a thought.
    May 2015
    Moorpark, CA
    171
    Quote Originally Posted by chiefwej View Post
    Makes sense. Thanks!
    Michael
    Aug 2014
    Northern IL
    4,615
    My lights are notorious for hiding algae and I clean them once/twice a year.
    Also if you have never cleaned your ladders you may be surprised at what's hiding there. This year we have had a lot of pools with tons of sludge in there, depending on the type of ladder.
  20. Back To Top    #20
    May 2015
    Moorpark, CA
    171
    MarianParoo - good to know. Sounds like I better take my lights out and clean behind them...while the water is still warm.
    Michael
