Thread: Vinyl Liner
    Jul 2014
    Yucaipa, CA
    46
    Vinyl Liner
    Moderator Note - Moved from here: So, how long will a vinyl liner inground last?
    We replaced the liner in out pool 8/2011 and it already has a hole in 2 corners of the pool. It's not on the seam so the warranty doesn't cover it. The corners are not flush (it's a rectangular pool and the vinyl is rounded at the corners on the top) so there's air between the liner and the corner of the pool hole. Is this normal? We had a professional order, measure and install the liner. We had seen some in magazines and he said that we needed so many mils (I think we got 20 or 25 mils) so it wasn't the cheapest liner out there. We're very disappointed - it may not even last to the end of the season or into next year.
    11,400 Gallons, IG Vinyl, Pentair 188592 Quad D.E. Cartridge Style D.E. Pool Filter 60 Square Foot 120 GPM, Pentair 011018 IntelliFlo Variable Speed High Performance Pool Pump 3 Horsepower 230 Volt, 1 Phase Energy Star Certified, replaced liner 8/2011, TF-100 Test Kit.
    ~Kellie
    Aug 2014
    Shallotte, NC
    693
    Re: Vinyl Liner
    Installers should really use foam cove in square corners. Another question might be: "what is poking holes in the liner?" Dogs? Kid's toys?
    Then, too, have you lost elasticity in the liner? If so, why? Chemistry?
    Liners should last significantly longer than 4 years.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Vinyl Liner
    It varies a lot with quality of liner and how well balanced the pool chemistry is kept. My last liner turned out to be low quality junk, it was ordered in a rush after an off road side by side ATV ended up in the pool ripping a gash in the shallow end floor (ATV was just back from the shop and someone missed reinstalling a return spring for the throttle cable). That liner lasted only about 4 years, by contrast my current liner is just now starting to show its age at 12-13 years, and may get replaced this winter, but could probably last another 2-3 years, maybe more
    Jul 2014
    Yucaipa, CA
    46
    Re: Vinyl Liner
    Thanks edkerns and Isaac-1. I don't think anything is poking holes in the liner. The dogs don't go in there and there are seldom kids in the pool and when there is, they are closely watched. One day I was swimming in the pool and I swear the second hold just appeared out of nowhere. The corners where the track for the liner is have space where water could get in so I don't know if some water got behind there and pressured the liner. I have been concerned about the corners since the liner was installed due to the air between the liner and the pool wall and the space for water to get in. As far as chemistry we had all kind of problems from 8/11 to 7/14 when I joined here and found out my CYA was literally off the chart. Since 7/14 everything has been fine for the most part. The foam coves make sense. Bummer about the ATV! I would have expected some age about 12-13 years - definitely not 4! I guess when it gets beyond repair I will try to find another installer. We may even check into guniting it. The hole is there and the plumbing is there so I don't know what it would take but it's worth checking into.
    ~Kellie
