Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: CYA levels keep declining...
    Jun 2015
    Dallas, TX
    148
    I'm a bit stumped on this one and was hoping for some help. We replastered the pool and filled it about 40 days ago (just bought the house and immediately did a replaster). At that point, I added enough stabilizer to get the CYA up to 40 (per PoolMath). Two weeks later, CYA measured in at 20. Again, I added enough stabilizer to get it up to 35 or so. A week later, it measured at about 25. I added enough stabilizer to get it up to 35 again. Today it measured at a bit over 20, maybe closer to 25.
    What on earth could be causing my CYA to continue dropping? We do have an automatic filler on the pool, but I rarely if ever hear it on, so I can't imagine it's auto-filling and draining the water constantly. Also had one big rainstorm which might explain one of the drops, but not all three. (Also, before anyone says I should have been targeting a CYA of 50 and not 35, I agree - I'm going to be out of town for 7 days in a couple of weeks so I was keeping the CYA lower so that I could use some pucks then and end up at a CYA I like).
    Any thoughts what might be going on? I thought CYA could only go down if water were rained and refilled. Thanks for any help.
    9,000 gallon IG pool with spa, Pentair FNS Plus 48 DE filter, 2HP Whisperflo pump, 0.75HP Letro booster pump, Polaris 280 cleaner, EasyTouch controller (originally a Compool LX100 that was upgraded via Pentair's upgrade kit), TF-100 kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: CYA levels keep declining...
    Your auto fill may be compensating for an auto-leak you have someplace.
    Jun 2014
    15,003
    Curious, do you remember what brand stabilizer you used previously? I had a similar problem with HTH.
    Jan 2014
    Buckeye AZ
    807
    I lose about 5 ppm per month, just using pucks yo bring it back up every so often. I do suspect there is a supply chain foe these various products that is putting out cya that doesn't behave as expected, just based on reading here.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Jun 2015
    Dallas, TX
    148
    Quote Originally Posted by woodyp View Post
    Possible, I suppose. Any easy way to determine if I have a leak?
    Quote Originally Posted by Texas Splash View Post
    It was HTH. First bottle was purchased from Walmart, current bottle is from Home Depot (but I haven't used much of it yet). I'll try something else next. What brand did you switch to?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Easy way to determine if you have a leak is to turn off your auto-fill, then do the Bucket Test. This is just putting a bucket on your steps or other solid feature that will keep at least some of the 5-gallon bucket above the pool water surface. Put a rock or other heavy object in the bottom of the bucket then fill the bucket to the same level as your pool. Wait a day or longer and if the water level in the bucket is higher than the pool, you have a leak.
    Isolated Spa - 345 Gallons
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Turn off the water supply to the autofill to see if the water level drops too much. Also, if your chlorine level spends much time below the minimum level then bacteria can grow that will consume CYA. Chlorine CYA Chart
    Jun 2014
    15,003
    FYI - I also got my first bottle of HT from Wal-Mart - lasted about 1 month then CYA started to drop. Tried a brand called Aqua Chem, and that seemed to hold a little better. Just bought another bottle of HTH from Home Depot about a week ago - waiting to test my CYA again after a week of dissolving. Kind of makes you go ... hummmm?
    Jun 2015
    Dallas, TX
    148
    Quote Originally Posted by JVTrain View Post
    How much of the loss would you expect to be from evaporation? That's definitely at play here in DFW.
    38,246
    My odd experience for CYA was also using HTH.
    Jul 2015
    Kentucky
    1,123
    I've had really good luck, and good holding of my CYA level with the Step 1 Clorox Chlorine Stabilizer Brand that I purchased from Lowes.
    EDIT: I'm really glad to read this because I certainly won't be getting the HTH brand because it looks like several of you folks have had issues with it.
    Lvrpl- If you have any left in the jug I'd take it back to Walmart because it doesn't work like its suppose to. If you have your receipt they'll give you your money back, if you don't have your receipt, they'll put the return amount on a gift card. That stuff is Not cheap, and nothing makes me any madder then spending good money on a bad product.
    24' Round x 4.5 ft deep AGP (15,200 Gallons), Vinyl Liner, Hayward Vari Flo XL Sand Filter- (model SP0714T1),
    TFTestkits , PoolMath , Pool School, RECOMMENDED LEVELS, SLAM & the Chlorine/CYA CHART. Support this Site! TFP Totally Rocks.
    Jul 2015
    Western NC
    115
    Quote Originally Posted by lvrpl View Post
    Today it measured [...] maybe closer to 25.
    ~20
    ~25
    ~25
    From what you're writing, you have not measured a CYA drop.
    Also, the TF-100 test kit measures CYA in tens if you follow the directions included with the kit.
    You don't lose CYA to evaporation. So measured CYA should increase as water evaporates, then back down as you add water.
    23,000 gallons IG gunite, pebble (I think)
    Hayward SP2610X15 1.5 HP Pump, Hayward sand filter
    Mineral Springs SWCG (it's actually Hayward/Goldline), Hayward Goldline T-CELL-15
    Polaris pool cleaner (with booster pump)
    TF-100, SpeedStir, K-1766 Taylor Salt Test, Lamotte Borate test strips
    38,246
    Yeah those test results are in the noise. Mine dropped 30ppm in a month.
    Jan 2014
    Buckeye AZ
    807
    Does cya have a shelf life degradation that we know of?
    Mar 2007
    San Rafael, CA USA
    12,082
    Kept cool and dry it has an unlimited shelf life.
    Jun 2015
    Dallas, TX
    148
    Quote Originally Posted by Sparkle View Post
    ~20
    ~25
    ~25
    Sure, I guess I'm saying there's an implied drop because I've been adding CYA but the level isn't going up.
    Fair point - I guess I'm interpolating a bit because the CYA test is relatively more tricky. I did it 3 or 4 times, it kept coming out somewhere between 20 and 30 on the TF-100 view tube (sometimes closer to 20, sometimes closer to 30). Also, I ordered and used some of the 50ppm CYA solution just to calibrate myself and make sure I'm looking for the correct "disappearance" of the black dot.
    Understood - my question about evaporation was actually referring to water in the pool and the bucket leak test JVTrain referred to above. However, you are pointing out why I'm confused on my CYA levels - it's not lost to evaporation, so where the heck is it going? Sounds like it's either a leak (which I'll check, but I honestly think is unlikely) or something is consuming/breaking down CYA (which I previously didn't know was possible, but sounds like it might be).
    My understanding before had been that CYA levels basically never change unless there is some water drained and refilled, sort of like CH. Sounds like it might not be quite that simple?
    Mar 2007
    San Rafael, CA USA
    12,082
    CYA slowly gets oxidized by chlorine, but this is not seen over days or a week but rather over months. The loss rate varies but is around 2-3 ppm CYA per month though some people see 5 ppm per month and we've had some reports of 10 ppm per month though that might be from other causes not yet understood. In hot spas the typical loss is 5 ppm CYA per month. Doing a SLAM will increase the rate of such losses, but usually a SLAM doesn't last for a month.
    Sep 2014
    Bakersfield, CA
    155
    I use BioGuard brand CYA purchased from my local pool store, addition amounts and test results pretty much line up with PoolMath. I try to maintain a CYA of 80, and see zero loss of CYA over the winter months. During the summer, with our endless days of full sun, daytime temps around 100F, and pool water temp over 80F, I see CYA losses between 5 and 10 ppm per month.
    Cheers, Peter
    20,000 gal, 52'x17' kidney shaped IG, Pebble Tec, IntelliPro P6E6VS4H-209L pump. Intellichlor IC40 SWG.
    300 sf Sta-Rite System 3 cartridge filter. Poolvergnuegen 4-wheel suction pool cleaner. TF-100 test kit.
    Jan 2014
    Buckeye AZ
    807
    so... who wants to set up two different buckets of tap water and add HTH vs Other cya and test the results?
  20. Back To Top    #20
    Jul 2015
    Bergen County, NJ
    110
    Has anyone used this brand of CYA from Backyard Pool Superstore? http://www.ebay.com/itm/291511544549...%3AMEBIDX%3AIT They sell on both Amazon and eBay and their prices are pretty low.
    53K Gallon Plaster in-ground with ALL Hayward equipment including Omnilogic Automation, Phantom Turbo Cleaner, SwimClear Cartridge Filter, Heater, Dual T-15 Salt cells. TF-100 Test Kit w/Speedstir.
