Thread: Questions about Intex SWG
    May 2008
    Southern Connecticut
    56
    I am considering buying the Intex SWG for this year. I looked at the Intex SWG post but was just wondering how would you close the pool when using one? I read that you don't have to add chemicals through out the season. Also I want to get the SWG before opening the pool so do I just add the salt and start the filter and pump? How would you check if the water is balanced? I know you can use the test strips but everyone on this forum is against test strips. Last summer I went to Leslies and they always checked the water for me. Is Leslie's Pool about to check the water with a SWG? Any information would be great.
    18' Willow round AG 52", 19" Sand filter 1 hp pump, Intex SWG 8110, Bought and install May 08
    New 12'x16' deck built March 09
    Poss thinking about solar panels next!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Questions about Intex SWG
    You need a good test kit, so you can stop going to Leslies. Seriously, it's the best way to take control of your pool and keep track of your water balance. IF you are going to go the SWG it's essential.
    The salt test strips are okay and actually preferred. Regular test strips for other chems are not. Get yourself a TF-100, you won't be disappointed.
    You can add the salt and start your filter, I think I read you need to wait a bit and make sure the water is balanced properly before you turn on the SWG unit though.
    About closing and winterizing an SWG - I don't know.
    What I do know is the last 2 closings I have added nothing to my pool except bleach, no "winterization chems" that Leslie's and the like sell to unknowning buyers.... and I've opened to crystal clear water twice and I looked under my winter cover now and it's crystal under there. If you read the ingredients label on the "winter kits" you'll see they are likely unnecessary for a properly balanced pool. I think the store by me sells them for $40 to $50 depending on the size of your pool, and they really are just a waste of money. Granular chlorine, algaecide and alk increaser. Other than the chlorine, I don't need to add them, especially not $50 worth.
    Someone will chime in about the winterization process for an SWG I'm sure. In the meantime, read all you can about adding salt, make sure you get the right kind, and go for it.
    May 2008
    56
    Thanks. I just ordered the tf100 test kit so hopefully not many (if none) runs to the pool store.
    An Intex SWG is normally disconnected, drained, and stored inside. Draining is critical, it doesn't have to be disconnected or stored inside, though both are a good idea.
    Quote Originally Posted by mastiffs08
    Statements like that can be misleading. When a SWG is working correctly, you won't need to add chlorine through out the season. But you will still need to keep all of your other numbers (PH, TA, CH, & CYA) in balance.
    New2Me's Avatar
    Jun 2008
    SW Indiana
    322
    I'd just like to add that a SWG is for Maintaining an established FC level. IMHO, trying to start-up with zero chlorine is not a good idea.
    22 x 40 IG vinyl lined, 23,570 gal.
    1 hp. Pac-Fab Challenger pump 300# sand filter
    Intex 8110 SWG, Hayward CL220 offline feeder
    Hayward 250K Btu gas heater
    Aquabots
