Results 1 to 17 of 17
Thread: Interviewing Builders in Cypress, Texas
    twinkiesmommy2009's Avatar
    Aug 2015
    Cypress
    1,679
    So I've met with 5 builders now? Anyhow, most are recommending Hayward, have been fine with and encourage my thoughts of an SWG, and mostly said all the same things. Then today, I met with another PB that had all different recommendations. He was a sales guy through and through but I wanted to at least research everything he told me. He's been doing this for 30 years in Texas, uses UV/Ozone (Ultra UV) with Chlorine pellets. He said SWG is going away due to issues with corrosion and they haven't used it for 3 years now. He said he was happy to provide me with the list of references on pools they've built. The others also recommended a vacuum where he recommended the in-ground PCC 2000 cleaner system. They are a big pool company that does a lot of warranty and remodels as well as builds in the area. He seemed really surprised that he was the first to tell me not to get an SWG. Thoughts?
    We got our first design drawing from a builder today. SO exciting to see it pictured in our own yard!
    Started 5/31/16. 38'x23', 618 sqft., <14,000 gallons, 8' spa.Travertine coping. Raised beam w/3 sheers. Large sunshelf w/3 bubblers. SWG IC40, Pentair VSP, 520 cartridge, color LED lights, Easy-touch, screen logic, Maytronics S300i robot, and Wet Edge Prism Matrix finish (Deep Sea Blue with Indigo plaster). Build Thread: Another in Texas - Cypress Texas | MUD District | HOA Approval | Great Escapes Pools
    Mar 2015
    Sugar Land , TX
    424
    Re: Interviewing Builders in Cypress, Texas
    Hate to be Mr Negative BUT, If you have not already done so search ozone systems and in ground cleaning systems on this site. Most do not like either system. Maybe that is why he does alot of warranty work! Oh and "pucks" "pellets" are not liked so much either.
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    We talked to 5 builders including the one you mentioned. Two of them refused to do a SWCG and the other 3 highly recommended against it.
    All of them wanted to add some combination of Ozone, UV and Nature2.
    In the end we were given the ClearO3 and Nature2 but I will deactivate after it's turned over to us. Unless I can stop them at install time.
    Good luck! Very exciting!
    Quote Originally Posted by rphpool View Post
    That's a bit of a stretch for the In Floor cleaning system. The people that have problems do seek help. But the reviews for the Paramount systems are mostly positive.
    We are getting the PV3 and I decided that on the positive reviews.
    Build thread
    IG Gunite w/ spa, PebbleSheen Blue Surf, 18K gallons 500sqft
    Jandy: 60 DE filter, 2.0 VS (main pump), 2.0 Flo Pro (features)
    Paramount PV3 w/ 1.5 Stealth, PDA PS6, JXi 400K NG
    Flagstone coping & wall. Stamped Concrete from BrickForm. TF-100 w/Speed Stir.
    Aug 2015
    Cypress
    1,679
    Can you tell me which builders you talked to? I've spoken with 5 other builders so far and he was the first to tell me that or recommend against the SWG. Are you in Cypress too?
    Quote Originally Posted by bdrums View Post
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You said it yourself he is a salesman, as to the other issues almost all pool builders will try to upsell the expensive, but often very low labor to install items like mineral systems, UV or Ozonator systems as it is easy profit for them. UV and Ozone systems do about as much to help a well balanced pool as pinstriping does to make a car go faster, while mineral systems add metals to the water (copper or silver usually) which make blond hair turn green and in high enough levels over time does the same thing to your pool finish. As to in floor cleaning, reviews are mixed around here, it is a major expense compared to other cleaning systems, seems to either work great or be constant headaches, depending on who you ask. Personally I know I would never buy one, instead I would stick with robot cleaners when they die replacement takes 5 minutes and there is no jack hammering concrete involved.
    Ike
    p.s. the only real issue with SWG's is they can corrode soft natural stones which are somewhat popular in Texas
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    If you want a novel on what you'll be in for that's also entertaining and local, check out Another Pool Build in Cypress, TX
    Isolated Spa - 345 Gallons
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    Quote Originally Posted by twinkiesmommy2009 View Post
    Sent private message. I'm in Spring in The Woodlands.
    Build thread
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    Quote Originally Posted by Isaac-1 View Post
    Maybe I haven't read everything you read, but most problems seem to be with the Caretaker system. I've seen very few problems with the Paramount systems. And I haven't read a single post regarding Paramount that indicated jack hammering concrete was needed.
    My thought was this was a choice you only get one chance at making and I didn't want to have to constantly "manage" a robot.
    Build thread
    Aug 2015
    Cypress
    1,679
    Quote Originally Posted by JVTrain View Post
    I read all 40+ pages!!
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    My sincerest apologies!! Lol! (well, you may not be Lol...)
    Suz.
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    It makes me laugh -- albeit nervously! -- to read this thread. Its so darned difficult to know whats what when you are a pool newbie and the PBs are all saying different things!!!! The 5 Maryland builders I met with have all been positive about SWCGs. I wonder if there is a climate factor driving regional recommendations?
    My Pool Build (2015): inground 12K gals gunite/plaster pool, SWG, 2-speed pump, cartridge filter, gas heater, and Dolphon s300i. TF-100 Test Kit w/ Speed Stir
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,580
    I'm in to watch this one!
    No to the nature2------it costs LOTS of money to use and causes many problems down the road (metals in water that build up over time).
    Kim
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I have not seen any issues to speak of on the Paramount system, but that does not mean that someone will not draw the short straw, I have also been around long enough to know that the companies that make the best products don't always survive and can leave you with an orphaned product. So I therefore tend to opt towards things than can be easily or at least practically replaced when possible. I also don't like the idea of that maze of connected plumbing under the pool in the event of an underground plumbing leak, I much prefer the idea of running as much plumbing as possible next to the pool instead of under it. I have dealt with underground plumbing problems under concrete three times with my pool (it was built in 1979, breaks were all in the last 12 years) and it is not fun, I am sure under pool is MUCH worse.
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by Helen203 View Post
    I think it is related to the typical pool decking and coping choices in each region. Flagstone and travertine are very common for builds in Texas. They also are the most susceptible to issues with exposure to salt water and corrosion. If cared for properly, there should be minimal issues with those as well, but many people do not do so and the builders would rather just avoid the possibility of another liability in their builds. I'm not sure what decking and coping material your build is consisting of but there tend to be more granite, brick, concrete, bluestone and possibly dense sandstone (non-flagstone or limestone materials) in northern climate builds.
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    Indeed. We can't predict the future. Can just make decisions based on what we think is the most likely scenario.
    Very prudent. I'm willing to take a little more risk so that I don't have to handle a robot multiple times per week. Risk/reward. I guess my tolerance is a little higher.
    That sucks. Sorry to hear. I've got plumbing running under (through?) the foundation of my house. I don't give it a second thought. Hope I don't have to. That's also why I didn't go with the cheapest builder.
    I don't know if I'll have problems or not. But from what I could tell, if history is any indication, I'm likely to have many years of reliability. So I'm betting that way.
    Build thread
    Oct 2013
    Spring, TX
    87
    Our pool was built by the PB you talked to today. We skipped the UV/Ozone but kept the PCC2000. According to Paramount, the PB is one of Paramount's most experienced and successful installers of the PCC2000 system nationally. The system works as designed and it's awesome. No robots in the pool and it's nice to mix up the pool water quickly after adding chemicals. Also, be sure to ask for a breakout of the cost of the PCC2000 system. Our pool isn't that large, and for us the cost wasn't that much more than the cost of a fancy robot.
    We did install the chlorinator, but it's currently not being used. It's nice to have the option to use Trichlor pucks when you go on vacation. We never wanted a SWG, so I can't comment on that.
    Choosing a pool builder isn't easy. For us, it came down to knowing our PB would build us a quality pool in timely manner. We have not been disappointed. We love our pool, and the whole construction process was refreshing. All the subs did high quality work and the PB only uses Modern Method Gunite for shell and interior. The construction supervisor was on site daily, and any issues or questions we had were dealt with promptly. They have scheduling their subs down to an art and we were always kept informed of who would be at our home and when. I have no other connections to our PB..we're just a happy customer and I believe that someone that does excellent work deserves a recommendation. Feel free to PM if you have any other questions. Good luck making your choice!
    15k gallon IG, 36' x 15', built April 2015, Pebble Sheen
    Pentair CCP420 cartridge filter, Pentair EasyTouch 8 controller, Sta-Rite Max-E-Therm 400K Heater
    Sta-Rite IntelliPro VS pump, Sta-Rite Max-E-Pro 1HP & 2HP pumps
    Paramount PCC2000 ICS, TF-100 w/SpeedStir
    Aug 2015
    Tomball / TX
    36
    The same PB you are talking about is in the process of building our pool. The decking starts tomorrow!! Although we are still in the build stages I have been extremely Happy. Every crew has done quality work and we have not had a single surprise or negative issue (with the exception of a little rain.)
    The PB also built a pool for a friend of ours about 5 years ago. They had great things to say about the PB and the pool (including the in floor cleaning system.)
    We originally wanted an SWG system, but decided against it. One main reason was from recommendation from a family friend of ours. They lived in Cypress and converted their pool from an SWG system to a standard chlorine system. They were having repeating issues witht heir patio furniture corroding due to the water. They said after going to a chlorine system the problem was solved.
    I will be happy to tell you more about our experience should you want more info. Feel free to PM me.
    Pool Area 510 Sq. ft, 94 Ln ft. 3'6" to 6', 18,120 Gal, Pebble Sheen, Pentair Clean & Clear plus 420 sq ft Cartridge, Pool pump Sta Rite Intellipro VS, Paramount pump sta Rite 1 HP Max E Pro, Water feature Sta- Rite 2 HP max E pro, PCC-2000 Cleaning & Circulation system, Rainbow Chlorinator O/L, Ultra Uv, Paramount Clear O3 Ozone system, Sta Rite Max E Therm 400k Btu heater. 2 Paraglo Multi Color LED, Paramount Paralevel.
