Thread: HELP Intelliflo stuck on ALARM
    May 2011
    SoCal
    12
    I have an Intelliflo VS pump.
    Not sure which one, it's about an year old, and is model 011018.
    Yesterday I noticed the pump was not running, and checked it out.
    The top line says ALARM.
    The Big Text in the middle says ALARM.
    The manual says to press ENTER and then RESET - this does nothing.
    I found a hard-reset that said press the top 4 buttons, then the middle 2 of the top 4, and Escape and Enter, then power cycle. This did nothing.
    I cannot get this pump to reset.
    ANY ADVICE OUT THERE?
    Thanks.
    Nick.
    ~15000 Gal Saltwater Pool. Jandy Controls. Too many kids.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: HELP Intelliflo stuck on ALARM
    How about killing power for like 5-10 minutes. Just let it sit there. And by killing power, I mean pull both legs of the breaker. Make sure no voltage is across the power leads.
    If that doesn't work, call Pentair: 1.800.831.7133
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Mar 2015
    Sugar Land , TX
    424
    Does the impeller spin?
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    chiefwej
