Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: New Pool Build- Sienna Plantation, TX
    Jul 2015
    Houston, TX
    16
    Hi TFP!
    My husband and I have spent the better part of 2 months studying up on here and I think we are finally ready to share our progress (or lack thereof!) so far.
    We both grew up with pools and have been saving up for ours for the last few years. We had 5 builders out, strongly considered 3 and decided to go with the mid-priced builder who gave us the best customer service. Really hoping we made the right decision here!
    A little about our design:
    15X30 Inground Gunite pool
    7X7 Spa (not raised)
    4X8.5 Baja shelf (16inch depth)
    Travertine coping
    480 Sq ft. Sundek, plus covering 150 ft of existing deck
    18 inch raised wall across the back, covered in white marble split face travertine
    Glass tile
    Wetedge Satin Matrix in Aqua Blue with Abalone Shells
    3 led lights in pool, 1 in spa
    2 Bubblers
    2 3ft rain descents
    All Jandy Equipment
    2HP VS Pump
    Booster pump for water features
    Polaris 9350 Robot cleaner
    400K BTU Heater
    IAqualink System
    *Iím sure thereís stuff I left off, but this is a good idea of where we are heading.
    If any one wants info about our builder, who else we got quotes/designs from, and how much this is costing, Iím happy to share in a PM.
    And now for Pictures!!
    30x15 IG Gunite pool, WetEdge Aqua Blue, Jandy Equipment, Cartridge filter, 2HP VS Pump, Polaris 9350 robot cleaner, 7x7 spa, 18" raised wall with 2 rain descents and 4x9 baja shelf.
    @ Tile and Coping Stage. Up next- Plumbing
    Jul 2015
    Houston, TX
    16
    Re: New Pool Build- Sienna Plantation, TX
    We signed our contract on August 10th and since then we have gotten HOA approval and called all the utility companies to come mark where the wires and such are. This has caused some issues.
    First, gas and electric are running through where we would like to put the spa. We had been warned by a few of the builders who gave us bids that this might be an issue so we are prepared to move those. What we aren’t prepared for is the Comcast conduit that runs directly through our yard. We don’t even have Comcast!
    We have a 8 ft. easement on the back of our lot and thought that this type of thing was supposed to run through that. We aren’t really sure what to do from here. Is this our responsibility to move since it shouldn’t even be there??
    We have a meeting with our builder on Thursday, technically do do our layout, but it is also the first time we will meet our construction manager so I’m hoping that he has some insight on next steps.
    Has anyone experienced this before? I would appreciate any insight or advice as this is really making us nervous and worried about the extra cost if this is our responsibility to fix!
    Jan 2015
    Austin, TX
    1,095
    Quote Originally Posted by mjkelley611 View Post
    The problem with Cable companies is they pay people very low wages to run cable. They will run it where ever they want to run it. The easement covers major stuff but not individual comcast lines. I am guessing they found a shortcut to your neighbor's house through your yard. You'll have to call them to have them move it.
    Pool is done! Only took 17 months! - Natural shape in-ground pool: 37x23, 505sq ft, 96ft perimeter, 7ft deep end, 18,950 gallons, tanning ledge, blue surf pebble sheen/luminous blue blend, Belgard coping, 910 sqft paver deck/walkways, retaining walls out the yinyang. Jandy SWG, 2 LED Color lights, VS 2HP Pump, 460sqft cartridge filter, PDA RS P8 controller. My build
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Welcome to TFP.
    Looks like a great project.
    Love the angles of the far wall.
    Are you going with Salt or traditional chlorination?
    What is the depth range?
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    Jul 2015
    Houston, TX
    16
    Quote Originally Posted by ummgood View Post
    Do you know if that will be at our own expense, or should they cover that?
    Quote Originally Posted by ozdiver View Post
    Welcome to TFP.
    Thank you!
    Ah, yes, those little details! We are going with traditional chlorine and the depth are going to be 3.5-5.5-4
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    The conversations often goes like this...
    You "There is a cable cutting through our yard outside the easement and it's not our service. Can you move it?"
    Them "Wellll, we can send out someone and it will cost you $$$ to relocate it. We can fit you in in 2 weeks time."
    You "What happens if it get s cut by accident?"
    Them "Ohhh, wel we send out the repair crew and they get is fixed."
    You " How much does that cost?"
    Them " Nothing."
    Jul 2015
    Houston, TX
    16
    You're my hero!
    Dreynolds's Avatar
    May 2015
    Palm Beach Gardens, Fl
    190
    I just had my yard flaged and AT&T was running there line diagonal through where my pool is going. I called them they sent someone out. Of course they wrote the wrong ticket. This was a repair guy. He was nice enough to go out there and was going to move it for me. And it wasn't even a live line. So they left it. Nice pool. Love the lay out!
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    Them " Nothing."
    EXACTLY what happened to me in Cypress with AT&T. After it was marked, they would not move it for free unless it was cut. So, you know the rest of the story! I was curious as to why they bother to pay someone to come out and mark the phone/internet line, since they have no intention of moving it until it's cut. Silence was the only answer I got.
    We also had to have our gas line re-routed. It took 3 weeks, but..... CenterPoint (not sure whom you have) was exceptionally professional about it. Gave me the entire process, what to expect, specific payment instructions, etc. I believe it cost $350. I just marked it off as one of those unexpected pool build expenses I expected. It was either pay for it to be moved or have the luxury of jumping out my back window right into the pool.
    Excited to see another Houston area pool build! It looks like it is going to be great! I LOVE the white marble split-face travertine; it is gorgeous!!! I seriously considered using that on my short raised wall.
    Take care,
    Suz.
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    Jul 2015
    Houston, TX
    16
    Quote Originally Posted by SuzfromTexas View Post
    Take care,
    Suz.
    Hi Suz! Thank you so much. It makes me feel much better that other people have been through this and now have beautiful pools! I read your whole build thread and your pool is amazing. Especially your glass tile!
    We are meeting with the construction manager on Thursday and we will come up with a plan from there. The good thing about building at the end of the summer is we have all fall and winter to get it done
    Jul 2015
    Houston, TX
    16
    Hi everyone!
    Sorry it has been so long since my original post, it has been whirlwind of action around here.
    When we had our construction manager out for layout, they looked at the Comcast line and figured it wasn't a big deal. We would hit it, they would run a temp line and no one would have any problems. We moved the gas and electric lines (not too expensive since they didn't need to move more than a few feet) and then we were on our way with the dig!!
    A few hours into the dig we got a text from our construction manager saying that the Comcast line was actually the main line for the neighborhood! He had never seen that before since it was a solid 4 feet outside of the easement! We went through several steps to try and figure this out and fix it, but no one seemed to see it as a big issue, so we moved ahead with our build.
    Rebar went in the next day and then stub plumbing. Pics below
    Jul 2015
    Houston, TX
    16
    Next was Gunite Day! our builder got us from dig to Gunite in only a week, even with all the cable issues.
    First step was to have the Gunite guys cut out the line. They cut through both ends and got to work! Several hours later a Comcast guy popped over the fence poking for a cut line. I guess it wasn't actually cut when they hit it during dig. Gunite was done by about 5, but the Comcast guys were in the yard until after 9 that night trying to repair the line. They have a temporary one in now, but we aren't sure what the long term plan is. We decided just to move past it, be excited about our pool and let Comcast figure it!
    Gunite pictures!!
    Everyone loves the Gunite!
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Poor Comcast.
    It doesn't matter how much you try to help them, they just can't help causing themselves issues.
    The shell looks great.
    What's the PB's next step?
    Jan 2015
    Austin, TX
    1,095
    Honestly that is what they get for having the main line for the neighborhood not in an easement. You have the right to use your property within reason for things like pools, etc... and that is why there is an easement for utilities so you can use the rest for what you want.
    Jul 2015
    Houston, TX
    16
    Thanks Ozdiver and Ummgood. We're glad to move on from the Comcast issue! Our builder has been great with working around it and keeping things on schedule.
    We are now in the middle of tile and coping. I'll post pictures of that this evening. So far I really love how all of our choices are coming together! I'm hoping that they will also get the plumbing done this week.
    Apr 2015
    Houston, Texas
    3,217
    I love the rounded backs of the spa benches! That's a great call!! It makes sense. My behind certainly isn't squared off!!! Lol!!!
    Looking forward to seeing the tile and the coping!
    Suz.
    Jan 2011
    Richmond, Texas
    595
    Looks really good. I am surprised Comcast hasn't sent you a bill to repair the line.
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,559
    Love how your pool is fitting in your yard with your patio! NICE job! CUTE pic of hubby and dogs! LOVE all three smiles!
    Kim
    Jul 2015
    Houston, TX
    16
    Quote Originally Posted by Flippy View Post
    Really hoping that doesn't happen....
  20. Back To Top    #20
    Jul 2015
    Houston, TX
    16
    Hi Everyone,
    Tile and coping are mostly in. They haven't finished the grout or the coping on top of the raised wall, but the builder when ahead and did the plumbing. We're hoping to have the equipment in, electric done this week and hopefully a layout meeting for the decking.
    I love my tile! it looks so different in different light and at different times of the day. Super glad we upgraded here!
