Thread: Conditioner for Vinyl?
    Aug 2014
    Phoenix, AZ
    3
    We live in sunny Arizona. Our pool (18x52 above ground Intex round) has held up really well, but we are concerned that the sun may damage the vinyl that is exposed at all times. I believe it is UV protected from the factory, but would like to know if we should be adding additional protection as time goes on.
    If so, what product would you suggest? There was not a lot of info on conditioning/protecting Vinyl pool material.
    I've googled Vinyl Conditioner, and the only thing I found was something called 303 Aerospace UV Protectant.
    Help?
    We have an 18' round, 52" deep Intex Ultra Frame above ground pool. Salt Water. We have a sand filter, and a chlorine generator.
    22,553
    Re: Conditioner for Vinyl?
    You found the best product out there for protecting against UV. 303 is used by lots of people in many different applications.
    As an RV'er and a boat owner, we use it for all the vinyl and rubber items on both units. It really makes the rubber seals last.
