Thread: Pool closing
    Jul 2015
    Novi/MI
    6
    Pool closing
    Hi,
    This will be my first full year and pool closing happens in 2 weeks.
    I have a Pentair filter. I don't remember the steps I took last year.
    I did a backwash until the level dropped below skimmer.
    Don't remember next steps.
    Should I put valve to Waste or Recirculate and turn the lever to Drain (right now it is set to "both" position) - pictures attached.
    Thanks
    Jun 2014
    15,093
    Re: Pool closing
    Hello and welcome! I wasn't sure what type of pool you have, but below are the pages to our most common closing procedures. Just use the one that applies.
    Closing an in-ground pool: Pool School - Closing an In Ground Pool
    Closing (winterizing) your above ground pool: Pool School - Closing (Winterizing) Your Above Ground Pool
