Results 1 to 12 of 12
Thread: Heads Up - CYA Sock Method - Keep sock off of coping - I etched my pool coping
    Feb 2015
    Santa Cruz, CA
    366
    Hello - just a heads up for anyone interested.
    I added CYA to our pool last week using the "Sock Method" and dangled the sock in front of a return jet - I just laid the top of the sock on the coping and put a weight on it to keep it in place over the return.
    I did this in two locations - one was on my stronger return - with the cover open - then I moved it to another jet when I closed our safety cover.
    I had the top of the sock draped up over the coping, and the slight ribbing in the sock etched my coping a tiny amount. I now have visible stripes on the surface of my coping that match the ribs in the sock!
    I did a little sanding to make it less obvious, but to get rid of it completely would require me to sand off the top layer of the very smooth concrete and start to expose more of the sand/aggregate.
    It would have been better to hang the sock on a pole extended out over the water in retrospect...
    I didn't see anywhere a mention of this anywhere, so I thought I would share my experience.
    2015 Build Link: 15'x30' Rectangle (3'-6", 5', 4' depth) 14,000 Gallon Pool, Finish: Wet Edge Primera Stone Black Kona. TF-100 Test Kit, Dolphin DX5+S Robot, Jandy CL460 Filter, VS 2HP pump, AquaPure 1400 SWG, iAqualink2, Automatic Safety Cover. No Heater
    Jun 2014
    15,131
    Re: Heads Up - CYA Sock Method etched my concrete pool coping
    Just to be clear .... from your description, are you saying that it was the rubbing of the sock itself (and not the stabilizer) that etched the coping?
    Feb 2015
    Santa Cruz, CA
    366
    No the etching was more from the ribs in the sock fabric hitting the coping concrete surface. Since the sock I used was slightly ribbed - those ribs are what were sitting against the surface. It didn't rub - just now there is a exact duplicate of my sock cloth texture etched into the concrete.
    Edit:
    Think of this texture etched into the concrete ever so slightly...
    Jun 2014
    15,131
    That is unfortunate. Almost like a "sock-print" of sorts huh? I've never heard of that happening.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    I wonder if the ribs could have acted as little wicks and wicked the acidic liquid and that did the etching???
    Support the site
    Feb 2015
    Santa Cruz, CA
    366
    Quote Originally Posted by tim5055 View Post
    That is most likely what happened.
    JoyfulNoise's Avatar
    May 2015
    13,206
    Pure Cyanuric acid is acidic. A saturated solution of CYA and water has a pH of ~4.8 according to this source. That is low and could possibly cause the damage that you see. Hopefully the sanding and continued weathering of the cement will even it out.
    In the future, you could always just put the sock in a blue chemical puck floater. That way it stays in the water and is less likely to cause any damage. I'm a "bad boy" and I put my socks of CYA in the skimmer, but I'm always careful to make sure the pump is running or else I pull the sock out and leave it in a small plastic container.
    Matt
    Feb 2015
    Santa Cruz, CA
    366
    I should have been more careful - but I now know!!!
    I think it will disappear eventually - a little sanding to make it fade away a little has helped.
    Thought I would post for anyone else to beware of allowing the sock to sit on any surface that could be damaged by the acid that invariably wicks up the fabric.
    Jul 2014
    Sacramento, CA
    241
    Quote Originally Posted by santacruzpool View Post
    It's a good point, and would be good to put in the various pool school places that mention CYA, not to hang the sock right off the edge -- when I did it, I tied a nylon cord around the sock, then around a 3' long stick that I hung over the pool, with a brick holding the stick down. The idea was to have it in the return stream but not have the sock touch the edge of the pool. Next time I'm going to try the other method of pouring in the skimmer to see how that works; a little less fuss that way. I need to clean my filter first though.
    21000gal IG plaster, Sacramento CA area (late 1950s/early 60s)
    Filter: Cartridge, Pentair CCP420 (2014)
    Main pump: Pentair IntelliFlo VS (2015)
    Boost pump: 3/4hp (2011), Polaris 280 cleaner (unknown age)
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    I toss my CYA sock in the skimmer.
    I've seen others ties a string/rope around the sock and with a weight on the rope, let the sock dangle in the water but I think that looks goofy so I like the more inconspicuous approach.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    May 2015
    13,206
    Quote Originally Posted by jmastron View Post
    The Pool School articles actually teach the method of putting the sock in the skimmer and not hanging it in front of the returns. So when you do use the skimmer method you still need to use a sock to hold the CYA and you must ensure that the pumps run continuously while the sock is in there. Pool School recommends running the pumps for 24 hours and no backwashing for a week if you use the skimmer method.
    Matt
    Feb 2015
    Santa Cruz, CA
    366
    Re: Heads Up - CYA Sock Method - Keep sock off of coping - I etched my pool coping
    I changed the title to better represent what happened - with a warning to keep the sock off of the coping...
