Page 1 of 17 123411 ... LastLast
Results 1 to 20 of 335
Thread: Pool Build -- Annapolis, MD
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    STATUS UPDATE
    8/29/15 Contract Signed
    9/4 Permit Issued
    Beginning Monday, 9/14/15
    Day 1 Dig (limited access = bobcat), pool equipment delivered, including 2nd light ~ thanks to TFP!
    Day 2 Dig
    Day 3 Steel
    Day 4 Plumbing
    Day 5 Inspection, Gunite
    Day 10 Electrician installed second panel in house
    Day 10 Tile selected, ordered
    Week 2-6 Electrician issues, work completed
    Week 6 Tile and coping
    Week 7 Decking scheduled
    April 1, 2016 Plaster scheduled
    Pool dimensions: ~17K gallons, 16'x34' free form, 4'-5'6"-4' sport, 496 sf, 98' perimeter, two 6' seats with added step out, sun shelf, 2-3' sheer descent waterfalls, DiamondBrite plaster, no spa
    Pump: Jandy 1.5HP Stealth, two speed, energy efficient
    Filter: Jandy Cartridge filter, 460 sf
    Heater: Jandy 400,000 BTU JXi Gas
    Lighting: 2 WaterColors LED light
    Sanitizer: Zodiac Aquapure salt system
    Cleaner: Polaris 360, no booster pump reqd
    Solid Safety Cover with Pump
    38,452
    Re: Contract Signed -- Are These Appliances OK?
    Definitely still get a two speed pump. And it seems that Raypak heaters tend to get the best reviews. Is the cleaner a suction cleaner or a pressure side cleaner or a robot?
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Hi Jason, I just called the PB and its a Polaris 360 pressure cleaner (I updated my specs above). The PB recommends this model because it doesn't need a booster pump. And I asked PB to LMK the price to upgrade to a 2-speed pump.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    Yeah, signing that contract can drain you (and your wallet). But boy will it be worth it.
    A few comments:
    I think you will find one light to be rather underwhelming except on the brightest color or two. Two lights would be better, facing away from the house/primary seating area.
    Yes, get a two-speed pump. On low they move 1/2 the water with 1/4 the electricity. Our electric rates are moderate but no reason not to be energy efficient. You will only need to run it on high for your cleaner, waterfalls and to skim/circulate quickly on occasion. Most of the time you will be able to run on low. Running on low a two-speed pump is also almost silent. On high it is noticeable. You generally won't leave the waterfalls running unless you are there and then maybe only if you are outside by the pool. If you run them all the time, you will be adding muriatic acid in large volumes, since you already have a SWCG which causes pH rise and therefore MA use. Adding MA is no problem per se, just expense and the time it takes to do it. I use just under a gallon per week with our SWCG pool and 27K gallons for reference. MA use at the beginning will be much higher due to the initial plaster (for up to a year).
    Make sure you are getting the PLC1400 model SWCG which is rated at 40,000 gallons (no problem being larger - 2-3 times actual size is recommended). The 12,000 gallon one is too small.
    What are you doing for decking?
    Feel free to show us a few before pics and a rendering if you have one!
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    One note, just so you will not be surprised later, the Polaris will need the pump to run at high speed to operate. Personally if it were mine I would skip the Polaris and invest in a drop in electric powered robot.
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Quote Originally Posted by bmoreswim View Post
    A few comments:
    Second light is too expensive for me
    Thanks for tip on which model SWCG -- very useful to know!
    We are contracting with separate contractor for decking, still haven't figured this out..
    And no actual rendering or construction plans to share yet.
    Quote Originally Posted by Isaac-1 View Post
    Good to know regarding high speed for Polaris. We've debated going for a robot, may have to wait to add that feature!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    +1. See my post to you in your other thread about cleaners
    I also agree, it will pay off big time in the long run to go with a 2 speed pump.
    Divin Dave,
    Aug 2015
    Simi Valley, CA
    87
    Quote Originally Posted by Helen203 View Post
    So we are in the middle of a pool build as well. Here is one thought on the robot. We told the PB to keep the cleaner that he was going to give with the pool and he gave us a $425 credit. When you look at the good robots they are anywhere from $1000 and up. If you take off the $425 then the robot gets a little more palatable to buy now instead of later.
    Build estimated completion October 2015, IG 21500 gallons, Agua Blue Pebble Tech,1xPentair Intelli Flow VSP, 1x3HP waterfall and slide pump, Pentair 520 soft cartridge filter, Nature 2 purification system, Pentair 400,000 BTU heater, Polaris 9550 Sport, Taylor K-2006.
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Re: New Pool Build in Maryland
    STATUS UPDATE
    9/4 Permit Issued
    9/14 Dig Scheduled
    My Pool Build (2015): inground 12K gals gunite/plaster pool, SWG, 2-speed pump, cartridge filter, gas heater, and Dolphon s300i. TF-100 Test Kit w/ Speed Stir
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Congrats, don't forget to post build photos
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Re: Pool Build -- Annapolis, MD
    The waiting is driving me crazy, but no rain in the forecast!!
    Jul 2015
    Dayton/Maryland
    83
    Maybe heat pump heater is a better choice.
    I don't like the Polaris, either. I personally like the pool robot with remote, such as:
    Amazon.com : Dolphin 99996356 Dolphin Triton Robotic Pool Cleaner with Caddy Swivel Cable, 60-Feet : Swimming Pool Robotic Cleaners : Patio, Lawn Garden
    2003 Build 20K gallon salt water gunite IG pool, Taylor 2006 test kit, Pentair 011018 IntelliFlo Variable Speed Pump, Pentair IntelliChlor IC40 SWG, Aquabot ABTTJET Turbo T Jet Robot
    Nectarologist's Avatar
    Apr 2015
    New York
    428
    Some unsolicited advice I would skip the cleaner for now and get the second light. You can always add a cleaner but you can't add a light. The LEDs are great imo but I know in my pool one would not be enough (I'm at 21k). I had my pb plumb a line for the polaris so I can always add it if it's wanted.
    Inground, vinyl liner, 16 x 32 (approx. 21k gallons), roman end w/ bench, 2 Jandy LED lights
    Pump: Jandy Flopro, 1.5 hp Heater: Raypak, 266k btu (P-R266-A-EN-C; nat gas) Filter: Jandy C340 (cartridge filter) Robot: Doheny's Dolphin Discovery SWCG: Circupool RJ45
    buccaneersdj's Avatar
    Aug 2015
    Largo/Florida
    76
    Congrats! We signed our contract on August 7th....STILL waiting for permit!
    17K gal IG Shockrete ff 30x20 446sq. 87' 3.5-6' sunshelf bub. 12" raised planter slv sf travertine 3' sheer descent 2 sconces brass Hayward StarClear Plus C17502 Cartridge filter Hayward AquaRite T15 Salt system Hayward Super 2, 2sp. 2 hp pump Hayward Colorlogic LED 1 pool in the deep 1 spa in shallow Coping Silver tumbled travertine Tile Noble Siren Decking 1500'Flagstone Cr/bg/ch Herritage
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Quote Originally Posted by Nectarologist View Post
    That's a really great idea, especially considering that our pool will be closed right after its filled and balanced (and that is assuming we get plastered this Fall and not early next Spring). Gonna discuss this with the PB on Monday. Thanks!!!
    Quote Originally Posted by buccaneersdj View Post
    ouch! Are you waterfront?
    4-inches today, wow
    Aug 2015
    Largo/Florida
    76
    4-inches today, wow
    No, not waterfront. I picked my PB based on several good reviews and 0 bad reviews...but I'd think after this long waiting on the permit as a PB I would have called the city to find out what the delay is..instead PB said "we haven't received a phone call or an email from the city stating there is a problem??? Well, I did call the city, come to find out the original drawing didn't pass and nothing else was submitted. A simple phone call from the PB and they also would have known this instead of telling me everyday "the permit is approved, just not ready to be picked up yet" GRRRR!!!! Beyond frustrated!
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Our dig is on, and all of the pool equipment delivered! As you can see, access is tight -- 7 feet and bobcat bucket is 6'4". The pool looks HUGE, tho it is actually about 500 sf. I did order a second light because y'all said to
    That spot used to be a pretty little pond -- frogs and fish are safely sequestered in a temporary pond. Everyone went to great lengths to save them all. I showed off my new frog log from Amazon.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    Very excited for you! Hopefully we get more dig pics than that though.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,580
    LOL Helen you DO have to watch us! We are VERY known to help others spend their money!
    Kim
  20. Back To Top    #20
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Equipment!
