Thread: Pentair WhisperFlo WFDS-28: repair or replace?
    May 2013
    Fort Salonga, NY
    15
    My Pentair WhisperFlo WFDS-28 has been making noise all season. It makes noise like it has loose parts inside and also vibrates. Bearings maybe???
    It is 10 years old. Should I repair or replace?
    Repair: replace bearings?
    Replace: just the motor (and a seal kit)? or replace the whole pump assembly (but then I would need to re-plumb?)?
    Any recommendations?
    Amazon has new whole pump assembly for $710.
    inyopools has new motor only for $390.
    Thanks in advance!
    38K gal, IG vinyl installed 2005, waterfall with separate pump, 2 skimmer baskets, 3 main drains, both pumps are 2 HP WhisperFlo WFDS-28 2-speed pump, Pentair Clean & Clear Plus CCP-420 420 sqft cartridge filter, AquaHeat LS MBP-150A Heat Pump, Dolphin Triton robot cleaner
    38,284
    Re: Pentair WhisperFlo WFDS-28: repair or replace?
    Consider upgrading to a 2 speed motor. There is not usually a need to replace the entire pump.
