Thread: power out no cool down for heat exchanger but seems ok but is it
    Jul 2012
    Whidbey Island, WA
    397
    have Maxi-Flo 260, old
    power went out while heating so exchanger had no cool down
    in bound water is 160 degrees and external metal casing was extremely hot
    power now back on and exchanger seems to be working as before
    so do I conclude it is ok?
    does this heat exchanger require a cool down? (have emailed the company)
    thank you
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Re: power out no cool down for heat exchanger but seems ok but is it
    Wouldn't think there'd be any problem. Max-Flo appear to be fully welded stainless water to water heat exchanger. Might be more concern about the oil heater dropping out without any circulation because that's where you'd have more of a hot soak risk, but guessing it's robust enough to survive the occasional power failures we experienced over the weekend. A rented space I have in Shoreline is still without power since Saturday.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Jul 2012
    Whidbey Island, WA
    397
    thank you
    still seems to working this morning
    pool 81
    water going into exchanger say 83/84
    water coming out of exchanger say 86/87
    from boiler say 155
    return to boiler say 120
    no leaks yet
    so I guess Ok but casing surely was hot
    thanks again
    I note you are in Seattle and around since 2008
    Ok to send you local pool queries?
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Sure, I'll send you a PM.
