Thread: Jandy Legacy inground pool heater
    Aug 2015
    SI/NY
    3
    When I turn the heater on after a minute or so it shuts off and display says; check Ign control. Should I change the ignition control or could it be something else? Thanks
    ps0303's Avatar
    Jul 2011
    FL
    3,703
    Re: Jandy Legacy inground pool heater
    It sounds like the flame sensor isn't sensing flame. So it lights and then goes out? Does it attempt to re-light?
    Pull the front panel off and look for a small grey box like item. That would be the ignition module. See if it has a red LED on it and if so, when this error comes up, is it blinking in a series of blinks?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Aug 2015
    SI/NY
    3
    Quote Originally Posted by RD1379 View Post
    PS0303, I have already ordered the sensor. Thanks for your help.
    Aug 2015
    SI/NY
    3
    Well I changed the sensor but that didn't work. I looked at the ignition module and it doesn't blink at all. it does try to re-lite it self 3 times before coming up "Check Ing control". My next option seems to be to change the ignition control. Am I correct or am I just wasting my time and money?
