Results 1 to 12 of 12
Thread: No, you DON'T have the worst pool problem
    Aug 2008
    Fredericksburg, VA
    51
    No matter how bad a problem you've ever had with your pool, at least it didn't look like this. Saw this on Twitter this morning from terriblerealestateagentphotos.com with the caption "If the weather clears up later I might mow the pool." and just had to share it.
    20,000 gal. free-form plaster on concrete
    Triton DE filter, 1.5HP pump
    Aquabot Elite pool cleaner
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: No, you DON'T have the worst pool problem
    Okay, here we go...
    Make sure you get a GOOD test kit with LOTS of reagent refills.
    First we start with a little bleach...
    Well maybe a machete, a weed whacker, and a LARGE dumpster.
    Then you are going to need to get a pool rake and make sure you get as much stuff off the bottom as you can. Keep trying to get as much out as you can, even if you can't see bottom.
    We'll be here when you are done with that. Shouldn't be more than a week or two...
    All joking aside, I would love to tackle this one. Given what I know now, I truly believe that since it still holds water, it is savable.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Aug 2008
    Fredericksburg, VA
    51
    And don't forget to order your TF100 test kit!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Better get the XXXL option!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    This has got to be the most neglected pool I've ever seen. Even if it were in good shape, it has to be an absolute nightmare keeping leaves out of it with all those trees/shrubs/vines surrounding it. Looks like that would be a year-round battle.
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    That is more an aquaponics project than a pool project.
    Greens on top, Koi Carp underneath. Merely needs an aeration pump and they are in the gardening business.
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Now where did I put my frog gig........................
    Donldson's Avatar
    NW Ohio
    2,926
    "Pool store said my numbers where fine, but my TDS was too high to use liquid chlorine. They told me to add 50 lbs of shock, 3 containers of phos-free, and several gallons of clarifier and I should be good to swim by Tuesday."
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Apr 2010
    East Texas
    9,659
    What,..........no phosphates??
    Donldson's Avatar
    NW Ohio
    2,926
    They didn't test for phosphates, just sold me the phos-free
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    Quote Originally Posted by Donldson View Post
    Serious laughing out loud here
    kk_isme's Avatar
    Aug 2015
    North Central Texas
    108
    Saw this on tumblr. Poor, sad pool.
    14,000 gallon above ground 24ftx56in round vinyl overlap liner steel wall sand filter 1/2 hp pump heavy lime in city water morning shade
