Results 1 to 12 of 12
Thread: Hi all- new pool owner here
    steve57765's Avatar
    Aug 2015
    Lexington NC
    47
    Got kind of late start this summer as my pool was complete first of August, about a month now.
    really liking it and learning all about pools and pool maintenance. So far so good (great) !! This is the first time I WANTED the summer heat to continue!!
    Pool was built by Anthony and sylvan pools , free from , pebble tec , nature2 , 19000 gallons
    Steve
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    Re: Hi all- new pool owner here
    Welcome and enjoy!
    Jun 2014
    15,150
    Nice to have you with us!
    Jan 2012
    'burbs of Augusta, Georgia
    7,350
    Hiya Steve
    Have you got a good test kit yet?
    steve57765's Avatar
    Aug 2015
    Lexington NC
    47
    Yep got the Taylor k5820 from Leslie's, after reading all the post I want to get a cya test, probably wait till next summer for that. I'm hoping my nature2 will work well, not so sure now, the bbb method seams like a good way to go, I'll at least use up all the chemicals Leslie's sold me.
    Jan 2012
    7,350
    In addition to the CYA test, you're missing a proper FC/CC test (the FAS-DPD test) which measures FC up to 50 ppm (a lot more useful when you have problems or high CYA and gives you the CC level)
    CYA test --> TFTestkits.net
    FAS-DPD test--> TFTestkits.net
    steve57765's Avatar
    Aug 2015
    Lexington NC
    47
    I do have Free chlorine and combined chlorine test is the one you noted different?
    Steve- 19K IG PebbleTec (sandy beach color pebble) final plaster/pebble August 2015
    Jandy pro cartridge filter
    Jandy pro series Plus HP PHPF pump w/waterfall
    Polaris 360 pressure cleaner- TF-100 w/SpeedStir
    50ppm Borates
    Jun 2014
    15,150
    Yes, they are different. The K5820 simply records levels up to 5 ppm with the drops while looking into the comparator window. The FAS-DPD, available via TFTestkits.net uses a combination of a powdered mix (R-0870) and drops (R-0871) to provide more accurate FC and CC readings. The FC can be recorded WAY above 5 ppm, most commonly used during a SLAM when accurate recordings are needed up to 10, 20 30 ppm. You can order just the FAS-DPD and still use your K5820 for pH, TA, and low-level OTO chlorine checks up to 5ppm.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    steve57765's Avatar
    Aug 2015
    Lexington NC
    47
    Hi all, pool update- after lurking these forums this past month, ( chem geek, every time I see your comments to questions I'm know there will be a professional, unbiased explanation/answer given. I have ditched the nature2, cut the mineral cartridge so that only the top with threads and seal remains, no more pucks in it, I will save pucks Leslie's sold me for times when away from pool for extended times to keep chlorine in pool. Added 45 lbs of boric acid to pool, my hair and skin feels much softer after swimming. I also got the TF100 test kit, great kit !
    I still have 2 jugs of Phos free and about 1/2 jug of perfect weekly left from Leslie's. Not sure what to do with them. Pool is crystal clear!!
    Thanks for all the pool information TFP web site!!!!
    Steve
    50ppm Borates
    Aug 2014
    Northern IL
    4,615
    Wow!!!! You have been not only reading, but taken the advice to heart. Good for you! Especially happy for ditching the Nature2 and getting a good test kit. You've done it before things got out of hand. Yay!!!! Enjoy!
    Jun 2014
    15,150
    Leslies may be willing to accept a return for the two unopened bottles. They've returned some things for me in the past. That right there would more than pay for your TF-100 investment.
