Results 1 to 9 of 9
Thread: Taking down an above ground Intex ultra frame pool
    Aug 2015
    toronto
    4
    Hi Everyone,
    this is is my first post.
    We live in Toronto Ontario and would like to hear from people who live in a similar climate and have an above ground Intex ultra frame pool.
    Must the pool be taken down for the winter? If so, can it be stored in a shed?
    thanks
    mario57
    12' X 24' X 52" Intex above ground Ultra Frame.
    1/2 hp pump, sand filter and a Raypack 106 Heater
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Taking down an above ground Intex ultra frame pool
    I used to take mine down and store it in our shed. Left my 18' up two years in a row, with now problems. I drained the below the intake, drained and removed pump, storing it in the Unheated garage. We had a really cold winter last year, with 15 below zero temperatures. When I took the pool down in June to give to a friend, the posts still looked very good and the liner looked great.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    I've left my 15' metal frame up for the last 4 years. Sure, we don't get the temperature extremes that you do, but I've had no problems with mine.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    In my reading here; I have noticed more trouble with leaks from folks who take them down and put them up from year to year, than from folks who don't
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jul 2014
    Oakbank, Canada
    389
    I live in Manitoba, where it gets -35 in the winter, so we take it down every year. SO far no problem...........
    I give it a good scrubbing, then drain it. Once drained I take some towels and give it a good wiping, and then dry it inside it. Then we wipe down the outside wall, and take it apart. As we fold it up, we wipe and dry each exposed area of the bottom, and then fold again. Takes me only couple of hours to do the entire process after the pool is drained.
    I store it all rolled up, wrapped in a fabric tarp, in a heated shop. I would not store in cold storage myself as I think that is just asking for trouble with cracks, etc later. My brother used to take his down into the basement once it was all rolled up for storage.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    I like that. The rolling up and the drying would make a big difference. Much less chance for seam splits and crease pin holes. I like that very much and will add it to my stuff to remember and suggest.
    Thank you very much for posting that.
    How many seasons on the same pool?
    Larryh86GT's Avatar
    Jan 2015
    Western New York
    93
    I have a Coleman Power Steel Frame 16' x 48" pool that we put up this summer. I am going to leave it up for the winter. A neighbor has an Intex steel framed pool and left it up last winter and it survived with no problem. And our last winter here was as cold and snowy as it could be. I have purchased a winter cover and air pillow and will hope for the best.
    Larry
    Coleman 16' x 48" power steel pool.
    Aug 2015
    toronto
    4
    Thank you
    what is the purpose of the air pillow?
    mario
    Hi
    has your friend had any issues with the pool?
    thank you
    Mario
    Larryh86GT's Avatar
    Jan 2015
    Western New York
    93
    This will be my first time using one but from what I have read a partially inflated air pillow goes under your pool cover to keep expanding ice from cracking your pool walls. It also helps keep some water off the cover.
