Results 1 to 15 of 15
Thread: Chemical storage?
    Jun 2015
    Dallas, TX
    148
    Chemical storage?
    Some comments on another thread made me realize I may not be storing chemicals in the best places. Where should one store the following chemicals? Assume no separate pool equipment shed.
    • Opened bleach - in the house (utility room) the best spot?
    • Unopened bleach - I keep this in the garage currently. Will the heat (I live in Texas so the garage easily gets 95+ degrees) cause any decomposition of the bleach? Someone suggested that even unopened bleach can cause rusting problems if stored in the garage - is that right?
    • Opened muriatic acid - I keep this in the garage. Someone suggested this may cause rust issues for metal (garage door springs, car underbody) in the garage - is that right? Where else do you store this?
    • Unopened muriatic acid - I also keep this in the garage, but someone suggested that even the unopened acid could cause rusting issues in the garage. Is that right? Where else do you store this?
    Thanks!
    9,000 gallon IG pool with spa, Pentair FNS Plus 48 DE filter, 2HP Whisperflo pump, 0.75HP Letro booster pump, Polaris 280 cleaner, EasyTouch controller (originally a Compool LX100 that was upgraded via Pentair's upgrade kit), TF-100 kit
    38,475
    Re: Chemical storage?
    1. Sounds good
    2. The heat will certainly degrade the bleach ... best to keep it climate controlled.
    3. I just leave mine sitting outside near the pool equipment (just make sure you do not have kids messing with it)
    4. Outside in a plastic storage shed.
    The MA opened or not can certainly cause damage to metal.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Bleach in laundry room or pantry. Heat does degrade it. Does not cause rust issues. *correction* bleach can cause rust issues, but much less than muriatic acid.*
    Muriatic acid outside in a shady place. Open and ventilated. Like under a deck. Muriatic acid will outgas and cause rust and corrosion issues.
    Jul 2015
    Western NC
    115
    What does a plastic storage shed like that look like ?
    Why don't you store the opened jug in it ?
    23,000 gallons IG gunite, pebble (I think)
    Hayward SP2610X15 1.5 HP Pump, Hayward sand filter
    Mineral Springs SWCG (it's actually Hayward/Goldline), Hayward Goldline T-CELL-15
    Polaris pool cleaner (with booster pump)
    TF-100, SpeedStir, K-1766 Taylor Salt Test, Lamotte Borate test strips
    DFW, TX
    24,509
    Jul 2015
    Western NC
    115
    Let me rephrase the question: it seems that I have to keep one or possibly two one gallon jugs of MA around. I don't want to keep it with anything else. Given that I don't have a nearby deck to store it under, what do I do ?
    Mar 2007
    San Rafael, CA USA
    12,082
    The Muriatic Acid will not degrade from higher temperatures so is OK to store outside. So put it anywhere outside (preferably in the shade just so it doesn't outgas as much) away from any metal. I keep mine in a pool storage box/bench, but it can be kept outside a box so long as you don't have any young children that would play with it. You could store it in a box with a lock if that were the case.
    rdshackleford's Avatar
    Jul 2015
    Coatesville, PA
    116
    Will unopened (sealed) muriatic acid outgas if kept in a cool basement?
    29,085.1 gal inground grecian vinyl, Hayward Super Pump VS, Hayward S-240 sand filter, Dolphin Nautilus Plus (aka Agador Spartacus), Taylor K-2006 kit, nice pool brush, crappy leaf net, frogs
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    My plastic shed with all my pool equipment inside. I store my muriatic acid in there inside the cardboard box it comes in. I suppose there are a few metal items in there so I should probably move it into one of my wooden sheds.
    All liquid chlorine gets stored in the house in a central closet so it gets the lowest temp swings and is in the dark.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by rdshackleford View Post
    Usually both acid and chlorine have tops that "vent". If your new unopened acid has a gas-tight seal on it and the basement is cool, then it may not outgas. However, I know both the chlorine and the acid that I get is not sealed and will outgas from the vented caps, but then what I get is in reusable jugs so that may be why they don't bother sealing them.
    Jul 2015
    Coatesville, PA
    116
    excelent, thank you.
    Quote Originally Posted by chem geek View Post
    Jun 2015
    Dallas, TX
    148
    If stored in a box, does the muriatic acid need to be in a vented box? I'm wondering if I can just get a plastic box (something like this: http://www.homedepot.com/p/HDX-27-Ga...NE-5/205978361) to store my muriatic acid in outside by my pool somewhere. Just wondering if the gases would build up in a box like this and cause a problem.
    Also great to know that bleach doesn't cause any rusting or corrosion problems. We just had our garage door motor replaced and the guy from the garage door company said that the previous home owners had clearly been storing chlorine pucks in the garage due to the high amount of rust on the garage door springs. Good to know liquid chlorine (bleach) doesn't do the same thing.
    Mar 2007
    San Rafael, CA USA
    12,082
    I would not say that chlorine does not cause rust. It doesn't cause nearly as much compared to acid. The Trichlor was worse because it's acidic and outgases more chlorine gas and nitrogen trichloride. Nevertheless, chlorinating liquid or bleach will also affect metal, but more slowly.
    As for the plastic box, you can always add some holes to it for venting. If you keep it closed, you just need to be careful if you open it in terms of fumes.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    I dunno. None of the (non-Hasa) chlorine or acid I get is vented as far as I can tell. The caps are just regular caps. Further, they always have an extra seal under the cap that needs pealed off or punctured. Now the Hasa chlorine crates I get are not sealed so they do outgas a bit...I can smell it when close to them.
    ----Chris----
    Jun 2015
    Dallas, TX
    148
    I my bleach in your regular 120 oz bottles from Walmart or Costco. The Walmart ones have a seal but the Clorox ones from Costco don't. Maybe that means the Clorox ones can outgas more?
    And I get my acid from Home Depot in one-gallon jugs. They're sealed also but it sounds like I can still get outgassing and rust issues if stored in a garage.
