Thread: Dolphin Supreme M500/M5
    Aug 2015
    Martin, TN
    3
    I got a Dolphin M500 a few weeks ago. I had a Tigershark before and it would clean the waterline. The M500 will climb the walls but rarely makes it to the surface/waterline.
    Any suggestions?
    Jul 2015
    239
    Re: Dolphin Supreme M500/M5
    Things to check:
    • Make sure the filers are clean. If they aren't, water is forced out the bottom of the unit causing problems climbing walls
    • Check the cleaning mode
    I hope this helps.
    - Flappy
    16,500 gallon IG Pool & Spa: Intelliflo VS pump, Pentair Triton II TR-100 sand filter, Teledyne Laars Lite2 propane heater
    Laminar Jets (2): Hayward Maxflow SP1600 1/2HP, Hayward Star Clear C500 cartridge filter
    Jandy iAqualink RS-8 Rev T, Hayward AquaRite AQR15, Dolphin Supreme M5, Taylor K-2006, Taylor K-1766
