Results 1 to 11 of 11
Thread: Newbie with an SWG - 2nd day - question on where to set percentages
    madgreen's Avatar
    Jul 2015
    Hurricane/Utah
    12
    We have had our pool for 30 plus days now. Our swg is on day 2 and our FC reading was a 3. We are running our 13,700 gallon pool pump for 9 hours a day. We currently have the percentage setting at %75. Where should we go from here on the percentage setting? I know to wait 24 hours between changing the setting. Any help is appreciated.
    thanks
    Madgreen from southern Utah
    13,700 gal, IG Plaster, Pentair 1 1/2 HP pump, cartridge filter, SWG (waiting 1 month, new pool) 7-23-15 built, filled w/city water Test Kit-Taylor K-2006
    May 2012
    Toronto, ON
    463
    Re: Newbie with an SWG - 2nd day - question on where to set percentages
    What is your CYA at? Keep testing the pool daily and see how the FC changes and just adjust the %age based on that once it is keeping at FC constant at your desired level.
    Vinyl 18'x36' in-ground 100,000 L, Jandy Aquapure 1400 SWCG, Jandy Lite2 heater, StaRite System3 filter, Evac tube solar heating panels
    madgreen's Avatar
    Jul 2015
    Hurricane/Utah
    12
    Haven't test the CYA today, before I started the SWG it was 36. I read to have the CYA 70-80. What is the best way to increase the CYA? Still learning this stuff, have never had a pool before. Thanks for your help.
    May 2012
    Toronto, ON
    463
    To increase CYA you add CYA aka Cyanuric Acid aka Stabilizer. But it takes a week for it to fully dissolve and show up in your test results.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Add the stabilizer in a sock and put it in the skimmer. Squeeze it several times a day to help it dissolve faster. Target 70 ppm CYA.
    More here on chemicals, what they do and how to add them,
    Here is my favorite saltwater pool page,
    Pool School - Water Balance for SWGs
    And here is the basics of pool water care,
    May 2014
    North Carolina
    18
    Welcome to the wonderful world of pools and their care! As you see, there a lot of variables involved in getting to your desired stable state. I've found that removing/stabilizing as many of the variables as possible to be a good approach. So, use Pool Math calculator to determine how much CYA to add to get up to your target (70-80). You can buy either solid or liquid stabilizer. Liquid is generally a fair amount more expensive but much quicker. Solid does take at least a few days to fully dissolve. Some folks use the sock method, some disburse over the pool area, some pour slowly into skimmer. Try to test your chlorine level daily and be consistent in where and what time you draw your sample. Remember that even with that, you can have swings in "normal" chlorine level based on changes in bather load, sunlight, rain/storm...The final variables are pump run time and % SWG time. If you intend on leaving your pump "on" time constant at 9 hours a day, you can begin to adjust SWG "on" % using your consistent chlorine testing results. It's a process and takes a bit of time to "dial in" your SWG for your pool and it's normal usage. I don't try and hit a specific number, just a reasonable range (based on CYA level), say 3-6. I tend to go higher in the range just to ensure an unexpected pool party (they do seem to happen) or tropical deluge doesn't bottom out (or nearly so) the chlorine level. It sounds like you're doing OK and I wouldn't be too quick to lower the % until you 'stabilize" the other variables as much as possible. With pools, slow and steady wins the race....unless of course it's a green mess and getting worse! I run my pump on very low speed for 15 hours a day. In my similar sized pool this allows me to drop SWG % to about 30% to generally maintain about 5 ppm Chlorine with a CYA of 70. Under most conditions, this results in a slow "creep" up in Chlorine level, so occasionally I'll dial it back to 20% to let Chlorine drift back.
    15K, IG, Sunstone Pearl (pebble) finish, Pentair EasyTouch 8 control system, Pentair IntelliFlo VS pump, Pentair IC 40 SWG, Pentair CC200 Cartridge filter, solar heating - 4th time pool owner
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    I like to use my SWG as "insurance" that my FC will never bottom out. But knowing that there is a finite lifespan to salt cells, I like to save extra wear and tear on my cell by letting it run at a low % level. When something happens (like when my grandson pooped in the pool!) that makes me want a fast rise in FC I use liquid chlorine (aka "household bleach") to raise my FC level to cover it.
    I would bring your pool up to desired FC level with liquid bleach, then let the SWG maintain that level and tweaking the % to fit the need. As your CYA level rises, so will your FC requirements. Please refer to this- Pool School - Chlorine / CYA Chart
    madgreen's Avatar
    Jul 2015
    Hurricane/Utah
    12
    Thanks for your help. Why does the chlorine range need to be between 3-6 on the FC? Does swg system need to be higher on the FC?
    thanks
    Oct 2014
    San Antonio, TX
    449
    Welcome to TFP.
    What size SWG do you have? Every pool will be different, but for a reference, I have a very similar size pool and a AquaRite 40k. My percentage has settled at 25% run time for 6 hours of pump time. I generally keep my FC at around 5ish and then check it once a week with the FAS/DPD to get an accurate reading.
    I also did not notice what you are using to test the water. Do you have one of the recommended test kits?
    BTW, I made a newbie mistake with my SWG this weekend. When I measured the FC Friday night, it was 3.5. It was an hour before the pump was going to shut off so I turned it to 75% to get a little extra boost - with the intent to test and reset % in the morning. Yeah I forgot to do that and did not test again until Monday after work. FC was 20+ (I simply stopped wasting reagent at that point). So I figure my SWG will be off for a few days.
    Free form 17X30. 14,500 Gal. Pentair sand filter and 1.5 hp pump. Aqua-Rite SWCG. TF-100 Test Kit w/Speed Stir
    madgreen's Avatar
    Jul 2015
    Hurricane/Utah
    12
    I am using a K-2006 Taylor Complete FAS-DPD Chlorine. Seems to be a good one.
    thanks Donna
    Jun 2011
    Long Beach, CA
    2,790
    Quote Originally Posted by madgreen View Post
    thanks
    Our recommended FC amounts are based on how much CYA is in the pool and is found here, Chlorine CYA Chart.
    The minimum amount of FC is the lowest amount that you should ever measure to prevent algae growth. If the FC drops below this amount for the amount of CYA in the pool then the pool is subject to algae growth. I like to measure at least the target amount to be on the safe side.
    If you compare the FC requirements for SWG and Non-SWG pools you will see that SWG pools require a little less FC for the same CYA levels.
