Results 1 to 7 of 7
Thread: Two weeks into TPF ... where do I go from here
    Aug 2015
    Grandy, NC
    135
    It's been two weeks enjoying TFP since three drainings, refills and pink slime. Current numbers are hangin' steady
    FC - 6
    CC - 0
    pH - 7.4
    TA - 100
    CH - 50
    CYA - 50
    Do I need to address the high TA now?
    Thanks.
    19300 gal, AG vinyl, 1 HP Pentair Dynamo two stage pump, 5 yr old Hayward Vari-Flo sand filter, pool 14 yrs old, well water, testing with Taylor K2006
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Two weeks into TPF ... where do I go from here
    If your pH is stable and your FC usage is predictable you can probably test every couple of days, just keep adding the FC so you stay in your FC range until time to close the pool.
    Love TFP? Become a
    TFP Supporter!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Usually with TA you watch the pH. If it starts to rise, use muriatic acid to lower. That will also, lower TA. As you continue to do that, the TA and pH will find their happy balance.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Exactly. Monitor your pH daily and see how much it rises over time. Every pool has a sweet spot for TA where the pH will lock in. It is just a matter of record keeping and muriatic acid.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    looking at those numbers and "where do i go from here?"
    the answer is nowhere
    you stay home and enjoy your pool
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    Aug 2015
    Grandy, NC
    135
    Thanks for the support. I never knew taking care of this pool (acquired only 4 yrs ago) could be so EASY. And aussieta you are right! Stay home and enjoy my Trouble Free Pool!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Congrats on getting your pool under control!
