Thread: Need a new impeller - problem Identifying Pool Pump model
    Feb 2012
    Dallas, Texas
    56
    I need a new impeller for my pump - the fins on the inside of the current one are breaking. The problem is that I simply can't figure out what model pump I have. I know it's an old Sta-Rite Max-E-Glas, and I have the label for the motor, but the pump label/plaque is long gone. I've looked everywhere.
    The motor is an AO Smith 2.5 HP, SF1.04, 230V, I think it's model 1081.
    On Amazon all the C105-137 and one of the C105-138 impellers look like the one I have.
    How do I figure out what impeller to get?
    Thanks
    IG plaster pool, 16000 gallons, Hayward DE6020 filter (120GPM) , 2.0 HP 230v single speed 1.3SR motor on Sta-Rite Max-E-Glas 1 pump, Polaris 280 (with Polaris 1.5 HP booster pump), spa.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: Need a new impeller - problem Identifying Pool Pump model
    Post some pictures...maybe someone here has a good eye.
    Amazon is good for returns...maybe buy both?
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Jul 2015
    Birmingham, AL
    39
    Quote Originally Posted by Agent99 View Post
    Yeah, Amazon is great for returns. I did find the link below that has the manual on it on a1poolfun. Pg 17 shows the impeller part#'s matched against the pump. Seems like the difference is single or double speed. Hope this helps.
    http://a1poolfun.com/nonmiva/pdf/own...ers_manual.pdf
    Installed 2010: 18X36X6ft 29000 gls, SWG, Vinyl Liner, Sand Filter. 2 skimmers/returns, Polaris cleaner aka Arthur, Heater
