Results 1 to 13 of 13
Thread: How to partially drain plaster ig pool to lower CYA
    Aug 2015
    Buena Park / California
    35
    My CYA is around 100-120 according to TF 100 testing kit.
    According to my reading, only way to lower it is by draining the pool.
    Please teach me how to drain the pool. I heard I could damage the pool if not done properly.
    I see a drain on the bottom of my pool, in the deep end, but I do not know how to activate it. I don't see any switch or lever around the pool.
    Only thing I see is just a lever for my DE filter to backwash.
    Can I just use the backwash function to drain the pool? If I just put pool vac in the only skimmer I have and switch to backwash I should be able to pump out the pool water safely without letting air into the pump right?
    And one more thing, why is my pump says WhisperFlo model no. WFE-3 on one side and A.O.Smith E-plus centurion switchless The energy saving motor on the other side??
    please help!
    13k gal / IG / plaster / DE filter
    May 2015
    Moorpark, CA
    171
    Re: How to partially drain plaster ig pool to lower CYA
    I can't help you with the motor, but I just performed some partial drains on my pool.
    Some pools have a valve to bypass the filter to drain. If yours does, the skimmer also needs a valve to pull water from the main drain, and not the skimmer. You can backwash through the filter, but it is recommended to pull the filters first. They are not designed for hours of backwashing, and are expensive to replace.
    My skimmer valve was missing when I bought my house (along with other pool parts), so pulling water from the main drain was out. Also, to me, if the valve failed, and started sucking air from the now dry skimmer, I didn't want to replace a burned out pool pump for hundreds of dollars.
    At the suggestion of a member here, I purchased a submersible pump from Harbor Freight. That was a good move. Easy to setup, and independent of the pool system, so no risk to the system. Here is what I got:
    Pacific Hydrostar 3/4 HP Submersible Dirty Water Pump Item 69299 about $60
    1.5" x 25' Heavy Duty Discharge hose Item 95391 about $15
    Hose clamp from Home Depot or auto parts store about $2
    Extension cord
    That's all you need, and you are ready to go! Be sure to plug this into a GFCI outlet for safety. No use getting electrocuted draining your pool.
    Michael
    20,000 gallon in-ground gunite/plaster pool (1992), attached spa with spillway, Pentair Superflo 1.5 HP pump, Smith booster pump for pool sweep, Pentair 2000 DE filter, Sta Rite Max-E-Therm 400 heater, Silencer Blower 2 HP for spa, Polaris 280 pool sweep.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Post us a pic of your equipment pad showing pipes and valves and someone here can probably figure it out for you.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Pool pumps have a wet end and a motor. The motor is usually made by a motor company like AO Smith and then Pentair makes the wet end and impeller and puts it all together and calls it a Whisperflow pool pump.
    Aug 2015
    35
    Thank you pooldv, now I got it.
    I wonder if using imgur is okay.
    here are some pictures of my pool equipments and pipes.
    Imgur: The most awesome images on the Internet
    Aug 2015
    35
    Here are some more pictures of my pool equipments.
    I have a switch that lights up a pool light, 1 skimmer connected to a pool vac, 2 holes on the side of the pool that returns water, 1 hole that fills up the pool when I turn the knob in above picture. I have a de filter, gas pool heater that is turned off. I have two timers and two shut off switches for the pool pump but only the right ones are working. PB once told me probably previous owner had a failed timer and instead of replacing it he just installed another one next to it.
    I still cannot find any switch or valve that might drain the pool. As you can see in above picture, there is a drain in the deep end of the pool.
    And is it normal for water to leak whenever I turn on the knob to fill the pool? Leak is coming from that white circular flat next to the knob that I turn to fill the water. Leak decreases as I turn the knob to full blast. Does that circular flat has a function?? I wonder what it does.
    Another couple question I have that is not related to this post:
    Is that a fire hydrant next to my pool?!? Its opening is already popped open and does not seem to be in use anymore. Just wondering what and why is it in my backyard next to the pool.
    And there are some cracks and chips around the pool grout and concreat. Does it pose any threat to the pool integrity? How do I fix it?
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Can you organize those pics into a folder that makes navigating them easier? Your other stuff is funny but....
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Aug 2015
    35
    Sorry, I know my post is bit messy but I am not very computer savvy.
    I am first time pool owner struggling to remove the stains on the bottom of the pool after slam due to green swamp.
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    TinyPic - Free Image Hosting, Photo Sharing Video Hosting might be a better photo hosting service. I thought Imgur was a site for jokes and funny pics?
    Aug 2015
    35
    Mobile Uploads by minkim002 | Photobucket
    I learned to use the photo bucket.
    please help.
    May 2015
    Moorpark, CA
    171
    "And is it normal for water to leak whenever I turn on the knob to fill the pool? Leak is coming from that white circular flat next to the knob that I turn to fill the water. Leak decreases as I turn the knob to full blast. Does that circular flat has a function?? I wonder what it does. "
    That's an anti-siphon valve, and no it should not leak. The diaphragm needs replacing.
    Michael
    Mark R's Avatar
    Nov 2013
    Desert Southwest, USA
    166
    What is that fire hydrant looking thing ?! I wanna know too maybe it's a the water shut off valve for your whole house
    12k gal Gunite/Hayward filter C5520BH with quad 33 inch filters. 2.5 hp motor. Pool is on south side, so full sun light. Spill over spa.
    Laar's heater LT250-Low NOx Gas Fired for pool/spa 250,000 BTU. Roof mount 6 panel solar system installed east/south. TF-100 test kit. May-September 100+ degrees out side.
    Aug 2015
    35
    Thank you Michael.
    And Mark, that is a fire hydrant however I look at it with one opening already popped out. Appears to be empty.
    wonder why that thing is next to my pool in my backyard.
