Thread: Spa pool BUBBLES will not stop!!
    Aug 2015
    New Zealand
    1
    Hi Everyone,
    We have a spa pool (M-Spa) which has always worked wonderfully. However over the past week when the heater goes on the bubbles have started up and gone for a few seconds a couple of times before stopping
    Yesterday when the heater came on so did the Bubbles - only now they go on EVERY TIME the heater goes on! and switch off when the heater goes off. The bubbles go on whether the bubble light is going or not, and Im not sure what to do about it If we turn the bubble switch on bubbles turn on, if we turn the switch off the bubbles stay on, they will not turn off! UNLESS you turn the heater off.
    So basically we cannot heat our spa pool without the bubbles going full bore which means having the cover and inner off the top of the pool and the water wont easily heat up.
    Any suggestions would be great, as the M-Spa company in NZ seem to have shut down.
    Thanks, Paul
    Jun 2015
    Wildomar, California
    423
    Re: Spa pool BUBBLES will not stop!!
    Hi Paul. Are you talking about an air blower? I'm unclear as to the nature of your issue.
