Thread: Two year old heater leaking.
    Aug 2015
    Marysville, Ohio
    1
    I had a pool installed two years ago and had a Raypak natural gas heater installed with it. I noticed it leaking a little a week ago and within a couple of days it was a major leak. The leak is coming from the heat exchanger. My pool guy told me that low pH of the water had destroyed the exchanger. Sadly I will admit that while I did maintain the pH last summer I really did little to maintain it this year. I do know it never got way out of line because I would have noticed it on the test strips. I am just wondering if it is surprising that the exchanger was destroyed so quickly?
    Thanks!
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Re: Two year old heater leaking.
    No surprise to me. I've seen it happen. I replaced a heat exchanger on a just over 1yr old Rheem. Then this summer I get a call from them again. Guess what? The heat exchanger I replaced almost a year ago, leaking. Very aggressive PH. It happens.
    BTW, test strips are not a good way to judge your pools chemicals. Get a decent Taylor test kit. Way better than those silly strips.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
