Thread: Liquid chlorine direct in filter or in The pool
    Aug 2015
    Arnhem/Netherlands
    109
    Hallo can i put liquid chlorine in The filter house or direct in to The water.
    in The Manuel i reed direct in to The filter house, or thoes that not The matter
    My spa is 225 gallon (ca 900 ltr)
    Factory is Caldera
    Above ground
    6 months old now.
    Jun 2014
    14,970
    Re: Liquid chlorine direct in filter or in The pool
    Please add chlorine (or bleach) to the water near one of your return jets with the pump running. Do not add it to the skimmer or near the filter. Have a nice day.
    Aug 2015
    Arnhem/Netherlands
    109
    Thanks
    Factory is Caldera
    Above ground
    6 months old now.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Here is a handy reference page that tells what chemicals are, what they do and how to add them.
    Aug 2015
    Arnhem/Netherlands
    109
    Thank jou.
    and Yes i,m using liquid chlorine 12,5%
    Factory is Caldera
    Above ground
    6 months old now.
