Thread: Stenner Tubing [1/4" or 3/8"]
    Jul 2015
    Woodbridge, VA
    18
    Is there any benefit in running the 3/8" vs 1/4" tubing for the suction/discharge on a Stenner install? Are most just using the 1/4" stuff? Thanks in advanced.
    V/r,
    Bryan
    15K Gunite; Pentair FNS Plus 48 - DE, Pentair Superflo VS, Raypak 2100 heater, Stenner 45MHP10 /w 15 gallon tank, TF-100
    Dec 2014
    Riverside California
    482
    Re: Stenner Tubing [1/4" or 3/8"]
    I use 1/4" black on mine. At a delivery rate of .89 Oz per minute for my 10 GPD fixed rate pump, that is not much volume.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Jul 2015
    Woodbridge, VA
    18
    Thanks!
    V/r,
    Bryan
