Thread: Gas Line Hook-Up
    Gas Line Hook-Up
    My contractor ran a plumbing line from my pool heater to the gas meter. They didn't do the hook up. It was my understanding that they would connect everything. Is it the norm for the gas company to make the connection into the meter or is the PB or contractor usually the one responsible for that?
    Thank you.
    19k IG Radiant Fusion pool, 750 gal spa, spillway and waterfalls, IntelliFlo VS / SuperFlo VS w/ Timer, Pentair Clean and Clear Cartridge Filter 420 sqft. Complete High Flo, IC40 SWCG, MasterTemp 400k BTU/hr NG heater, Pool Cleaner suction-side cleaner, IntelliTouch/EasyTouch 8SC controls w/ ScreenLogic2, city water supply, Intellibrite Pool/Spa Lights, Hayward IG Skimmer
    May 2012
    Toronto, ON
    463
    Re: Gas Line Hook-Up
    Maybe the contractor isn't licensed to work on gas. You often find that is the case - anyone can rough it in but the final connections have to be done by a licensed gas dude.
    Vinyl 18'x36' in-ground 100,000 L, Jandy Aquapure 1400 SWCG, Jandy Lite2 heater, StaRite System3 filter, Evac tube solar heating panels
    Jun 2015
    Rocklin Ca
    78
    Being a retired plumber I've hooked up many lines from meters, the gas Co. is responsible for the gas feed to the meter and the actual meter. IMO the contractor should hook it up. Also if I was running the line I would have started at the meter and worked towards the heater, no big deal defiantly will need a union or Right/Left hand nipple. Keep in mind codes might be deferent in your area call the gas Co. see if they are responsible. BTW i'm sure theres a 24 hour test required by the city.
    In ground 20,000gal - pebble-tec - salt, Intelliflo pump, Sta-Rite filter 450 sq ft ,Hayward 6060 booster pump, non functioning Aqua Rite SWCG, TF 100 test kit.
    Jun 2012
    western NY
    1,559
    Who does the hookup all depends on the area of the country and the local rules. In my area, the homeowner can do work on anything on the house side of the meter. The gas co. will require a 15 min air test for any "turn-ons" but doesn't require anything for existing work here.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    JoyfulNoise's Avatar
    May 2015
    13,173
    In Tucson, if you want to hook up any new gas equipment to the existing meter, it has to be done by Southwest Gas. The plumber has to stub it all the way up to the meter and ensure that it passes pressure/leak testing and then the gas company will hook up the line. One reason for this is the gas company may have to install a larger gas meter on your property as the meters are rated to deliver only up to a set number of BTU/hr. My gas meter, because of the outdoor fire pit and pool heater, is one size larger than all of my neighbors.
    Matt
