Thread: Ultra Violet Pool Filter Light
    Aug 2015
    Butler, MO
    2
    I was advised recently that there is a new product being offered as a UV Light which greatly reduces the need for the use of adding chemicals to the pool in order to reduce or eliminate the growth of algae. Has anyone heard or seen of such a product?
    My name is "Gary". I am a new pool owner. I have a 24 foot diameter by 52 inch above ground pool with a Hayward Swim Pro Voyager Filtration System.
    Donldson's Avatar
    NW Ohio
    2,926
    Re: Ultra Violet Pool Filter Light
    You were advised poorly. UV is not new, there are plenty of options on the market that claim to reduce chlorine use. Long story short, no it will not. A UV system is not helpful in an outdoor residential pool. The places a UV system is helpful is an indoor pool that does not get sunlight or a public pool with a high bather load. In a normal residential outdoor pool UV will rarely decrease chlorine use and can possibly increase it.
    The best way to reduce chemical use and cost and eliminate algae growth is to follow the TFPC method of pool care. By accurately testing with a proper kit and maintaining your FC according to the FC/CYA chart you will not have algae problems nor need any costly extras like algaecide, phosphate reducers, or UV systems.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Waste of money in your situation.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    What they said, the bit about saving on pool chemicals is a twisted half truth that only applies to pools that already have algae growing in them. In a well balanced pool a UV system will increase, not decrease chlorine consumption.
    Mar 2007
    San Rafael, CA USA
    12,082
    See this post for some questions you could ask whomever advised you about the UV system.
