Thread: Scuba 2 measure
    Aug 2015
    Arnhem/Netherlands
    109
    Scuba 2 measure
    Total chloor 3.1
    free chloor 1.4
    ph 7.7
    Ta 114
    cya 73 (correction) it is 55
    thats iT.
    what are The recommended levels.
    i have see The pool scool but The levels confusing me
    My spa is 225 gallon (ca 900 ltr)
    Factory is Caldera
    Above ground
    6 months old now.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Scuba 2 measure
    The Recommended Levels in the Pool School are for pools, not spas. For spas when using chlorine you look at the sticky Using Chlorine in a Spa where IF you use the Dichlor then bleach method then you lower your TA to around 50 ppm, use 50 ppm borates (from boric acid), target the CYA to around 30-40 ppm so switch from using Dichlor to using bleach at that point (looks like you went somewhat past that but that's OK), and have Calcium Hardness (CH) at around 120-150 ppm to prevent foaming. The pH is usually in the 7.5 to 7.8 range.
    In Europe, you may not be able to get boric acid so pH control will be more difficult for you when you switch to bleach. Aeration will raise the pH. If you lower your TA that will lessen the rate of pH rise but you should have some alternative pH buffering which is what the boric acid do. If you have your TA low and are using bleach, just make sure you check your pH and don't let it get much above 8.0. You want to prevent scaling in your spa. If the pH, CH, and TA get too high in combination, then that leads to calcium carbonate scaling.
    Aug 2015
    Arnhem/Netherlands
    109
    Re: Scuba 2 measure
    Thanks chem geek.
    And yes i,m using 12,5 % Bleach.
    Sorry chen geek,
    My cya is 55 (correction)
    Factory is Caldera
    Above ground
    6 months old now.
