Thread: Need a new SWG
    Mar 2012
    west central Texas
    21
    Need a new SWG
    Our Swim Pure T Cell 15 SWP recently quit working after 3 years and would like advice on a replacement Cell. Not sure if we need to stay with the T 15 SWP (? on what SWP means) or if we could change to a different brand/generic and still use our Swim Pure Plus panel?
    18,500K gal, IG vinyl, sand filter, Swim Pure Plus SWG with a T-Cell-15-SWP, 1.5HP Hayward pump, Built 2008
    Jan 2012
    'burbs of Augusta, Georgia
    7,359
    Re: Need a new SWG
    Are you *sure* it quit working and not a chemistry problem or has the cell worn flat out and just need replacement of the cell only.
    TFP recommends SWGs be sized 2-3x the size of the pool so it can be run at lower % to extend its lifespan.... never mind- I see yours was plenty big enough
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Need a new SWG
    If the cell is depleted, you can buy a T-15 replacement cell on Amazon for $400. I got 7+ years out of a T-15 in a 19k pool that stays open year round, so 3 years sounds a bit on the short side. However if the water wasn't kept in balance or if the SWG has been set at a high percentage, that would have hastened is demise.
    chiefwej
    Jun 2011
    Long Beach, CA
    2,790
    Re: Need a new SWG
    Replace it with any T-15 cell as they are the same as far as the different lingo goes. Some T-15 cells have one year warranties while others have 3 year warranties and the price is not related to the warranty.
