Results 1 to 14 of 14
Thread: Intex LED lights :)
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Intex LED lights :)
    Here are a couple video's of my LED install on our intex pool... enjoy
    These are 12 volt DC 5050 WS2811 LED's, I used 6, 5 meter strip's... This is not an easy process to make this happen and the LED are the cheapest of all the install
    Jun 2014
    15,153
    Re: Intex LED lights :)
    That's neat CC. I feel like I'm back home in Vegas. Lights baby! Lights! Nice work.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,103
    Been wanting to do something like that for my pool. How do you keep them waterproof? Also, are they rated for use near water?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,103
    Love the purple color. Make the water look florescent. Wife would really like that.
    Jul 2013
    Fletcher, OK
    3,353
    Quote Originally Posted by pabeader View Post
    ok, here it goes... deep breath....
    they are IP68, so they are rated to be directly in water... with that said, I siliconed the you know what out of the ends, any power wire and connection... They are 12 volt dc so not a lot of power but I did not take a chance... they are also behind the liner inside the track where the bar goes..
    with that said, This is not an easy thing to do.. it took me the last 3 years of trial and error doing these lights to get them right... just the power supplies are a pain, this one is a 60 amp travel trailer power supply.. the one running my house LED's is 100 amp..
    Jul 2015
    Fort Worth, Tx
    8
    Wow I was thinking about doing the same thing could we get a close up on how they are mounted an the way you waterproof the ends
    6k gallons,1648 Intex AB,.95hp intex sand filter mod 28651eg, set up may 2015
    Jul 2013
    Fletcher, OK
    3,353
    Quote Originally Posted by gjon91 View Post
    I do have some pictures but will need to upload them tonight
    Jul 2015
    Fort Worth, Tx
    8
    Cool I've been watching the video trying to figure it out with no help where did you purchase the LED I like the effect how they chase each other in the white color
    Jul 2013
    Fletcher, OK
    3,353
    here is almost everything I used to install these led's.. Please know that this is not an APPROVED LIGHTING, it has no NEC approval... please research and know the risk and take responsibility for what you do...
    I was going for safety not pretty There is no way possible for water to get into the silicone... check everything including powering on the lights before you silicone, you can guess how I know
    Parts
    SPI Controller WiFi Controller WS2811 WS2801 6803 1903 LED Strip & Remote WF300
    http://www.ebay.com/itm/281635728360...%3AMEBIDX%3AIT
    12V WS2811 1 IC- 3LEDs 30 48 60 leds/m Digital Dream Color LED Strip Light
    white PCB, 60 LED/M, IP68, 20 Meters...
    http://www.ebay.com/itm/311113572503...%3AMEBIDX%3AIT
    I have both the 60 amp (for pool lights) and the 100 amp for house... These are awesome and also have an external bonding lug...
    Powermax Boondocker Converters
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,103
    Darn it! Both the ebay links are dead!!
    Jul 2013
    Fletcher, OK
    3,353
    No problem
    do a search on ebay for
    LED IP68 12v ws2811 strip
    and
    Remote WF300
    Jul 2015
    Fort Worth, Tx
    8
    Amazon.com: NEWSTYLE SMD5050 Fully Submersible LED Strip, IP68 Waterproof 5M/16Ft 5050 300LEDs RGB Color Changing LED Flexible Strip Lights 44 Keys Infraed Remote Controller: Home Improvement. this is what I found do they look like they would work for how you set up your. Now to figure out how to connect two strips together
    Jul 2015
    Kentucky
    1,126
    The lights look great, CC. You did an awesome job on them.
    24' Round x 4.5 ft deep AGP (15,200 Gallons), Vinyl Liner, Hayward Vari Flo XL Sand Filter- (model SP0714T1),
    TFTestkits , PoolMath , Pool School, RECOMMENDED LEVELS, SLAM & the Chlorine/CYA CHART. Support this Site! TFP Totally Rocks.
    Jul 2015
    Fort Worth, Tx
    8
    Cowboy Casey how did you get your lights not to lose power (dim lights) when you hook two strips together
