Results 1 to 8 of 8
Thread: Pool Party
    Jul 2015
    Ceres Ca
    18
    Pool Party
    I'm having a pool party this weekend I wanted to know if I need to make any changes on the run time of my equipment I run it on a daily schedule from 7a.m to 1p.m
    My readings are as follows
    FAC 5
    TAC 5
    SALT 2900
    CH 200
    CYA 50
    TA 120
    PH 7.6
    PHOSHATES 400
    Any feedback will be appreciated..thanks
    live in central valley pebble Tech 18920 gallons pentair pump sheer decent salt water IGP built June 2015
    Jun 2014
    15,121
    Re: Pool Party
    Just a few concerns that caught my eye:
    - Where did those test results come from? The TF-100 and Taylor K-2006 don't test for phosphates. Are those pool store readings?
    - For a SWG pool, your CYA is low and should be increased to at least 70
    - Beware of your CH. It appears to be low for a SWG/plaster pool (min 300)
    None of those items effect your pool party itself, but are something you should be aware of down the road. You may also want to consider raising your FC level by 2-3 ppm before guests arrive and check afterwards to see if the swimmers load put too much stress on your FC. Have a great weekend!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    Re: Pool Party
    Bump your FC up a few points before and after the party with plain bleach while circulating.
    Jul 2015
    Ceres Ca
    18
    Re: Pool Party
    Yes the readings are from leslies
    Can i just increase the time on my generator to bump fc?
    Aug 2014
    Shallotte, NC
    693
    Re: Pool Party
    Collectively, we have found that pool store test results are VERY inaccurate. So, it is not helpful to try to advise you, using what are likely numbers that are not truly representative of your pool.
    You must take total control of your pool, including testing.
    Apr 2010
    East Texas
    9,602
    Re: Pool Party
    Quote Originally Posted by Vcjplove View Post
    Yes you can....it's just much easier, quicker, no fumbling with settings and more accurate doing a one shot bleach dump. I'd add a gallon and a half and be through.
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Re: Pool Party
    Quote Originally Posted by woodyp View Post
    An added plus to Woodyp's suggestion is it limits the wear and tear on the SWG (which have a finite amount of hours run in them before they go kaput) and using bleach is instant rise instead of a slow steady rise.
    Apr 2010
    East Texas
    9,602
    Re: Pool Party
    I knew I left out a couple more good reasons!
