Results 1 to 10 of 10
Thread: Lithium Hypochlorite Chemistry
    Jul 2012
    Saugerties, NY
    447
    I've been thinking about Lithium Hypochlorite, and I'm wondering why it doesn't have any of the negative side effects we see from Calcium Hypochlorite. I realize there is a difference between Lithium and Calcium, but shouldn't there be a risk of forming Lithium Carbonate once the water becomes saturated with Lithium?
    TreeFiter
    Pool Technician
    Saugerties, NY
    JoyfulNoise's Avatar
    May 2015
    13,195
    Re: Lithium Hypochlorite Chemistry
    Yes, but the solubility of lithium carbonate is much much greater than calcium carbonate -
    CaCO3 solubility = 0.013 g/L at 25C
    Li2CO3 solubility = 12.9 g/L at 25C
    So the solubility difference is a factor of 1000!
    Matt
    Jul 2012
    Saugerties, NY
    447
    Interesting. I did a quick google search on Lithium Carbonate, and the descriptions I found made it sound like it was not very soluble. I guess relative to Calcium Carbonate it is.
    So does this mean that it is possible to cloud the water with Lithium Carbonate, but very unlikely because of how much Lithium would be needed to do so?
    TreeFiter
    Pool Technician
    Saugerties, NY
    Mar 2007
    San Rafael, CA USA
    12,082
    Very, very unlikely, as in you will never see it happen. At usual pool pH and TA calcium carbonate saturation occurs with the CH at roughly 300 ppm. With lithium carbonate being 1000 times more soluble, you'd have to get your lithium levels to the 300,000 ppm range (in calcium carbonate weight units) and as you know even using chlorinating liquid or bleach for years doesn't get the salt level anywhere near that high.
    You need to think of lithium more like sodium than calcium. Compare the solubilities and solubility products in this link where I list the carbonates in order of least to most soluble (sometimes solubility is higher than the solubility product implies due to ion pairs):
    Mercury(I) Carbonate 0.000045 g/L solubility; KSP 9.52x10-15
    Lead(II) Carbonate 0.0011 g/L solubility; KSP 7.4x10-14
    Cobalt Carbonate KSP 1.4x10-13
    Manganese(II) Carbonate KSP 1.8x10-11
    Iron(II) Carbonate KSP 3.2x10-11
    Copper(II) Carbonate KSP 1.4x10-10
    Nickel(II) Carbonate KSP 6.6x10-9
    Strontium Carbonate 0.01 g/L solubility; KSP 4.59x10-9
    Zinc Carbonate 0.01 g/L solubility; KSP 1.4x10-11
    Calcium Carbonate 0.014 g/L solubility; KSP 2.8x10-9
    Barium Carbonate 0.02g/L solubility; KSP 1.03x10-8
    Silver Carbonate 0.033 g/L solubility; KSP 8.1x10-12
    Magnesium Carbonate 0.106 g/L solubility; KSP 3.5x10-8
    Lithium Carbonate 15.4 g/L solubility; KSP 2.5x10-2
    Sodium Carbonate 211 g/L solubility; KSP 1.2
    Potassium Carbonate 1120g/L solubility; KSP 2130
    Ammonium Carbonate 1000g/L solubility; KSP 4520
    You can see that magnesium carbonate is around 7-8 times more soluble than calcium carbonate which is why with most hard water you see calcium carbonate scale first. It's possible to have water high in magnesium and not calcium in which case you could get magnesium carbonate scale but that is unusual. You can see the very large jump in solubility going from magnesium to lithium. For practical purposes, you can consider lithium, sodium, and potassium carbonates to be very soluble in pool water at concentrations you could have in such pool water. You can also see that there are many metals that can precipitate with carbonate including zinc, nickel, copper, iron, manganese and cobalt, but metal ion concentrations are far lower so in practice you don't see zinc carbonate and for the other metals you're more likely to see oxides-hydroxides of those that are less soluble than the carbonates.
    May 2015
    13,195
    I think your bigger concern is the cost premium. Based on Leslie's web prices -
    24lbs of Li-hypo (35% available chlorine) is $130
    24lbs of Cal-hypo (73% available chlorine) is $105
    ($130/$105) x (0.73/0.35) = 2.56
    So your paying more than 2-1/2 times as much for the same amount of chlorine. That's awfully high premium to pay just to avoid managing calcium scale.
    Matt
    Jul 2012
    Saugerties, NY
    447
    The cost is certainly a drawback. The only reason I'm considering it is because I've started to see Calcium cause problems in some pools. Its not so much a scale issue as it is a cloudy water problem. Of course my other option would be Liquid Chlorine, but its difficult to carry around in the quantities I would need.
    In my situation the cost isn't necessarily a problem for me, but I'm sure there will be some push back from customers when they see they are paying twice as much for chlorine. It would only be used occasionally, assuming we are doing things right.
    TreeFiter
    Pool Technician
    Saugerties, NY
    May 2015
    13,195
    Quote Originally Posted by TreeFiter View Post
    Well, your other option is to get SCBA certified and start offering chlorine gas injection service. Nothing beats pure chlorine gas!
    Matt
    Jul 2012
    Saugerties, NY
    447
    Scary stuff! I'll stick with really expensive grannulars.
    TreeFiter
    Pool Technician
    Saugerties, NY
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    I've wondered what kind of PPE the pool companies use when they mess with chlorine gas. We use it at work, and you don't want to be around it without protection.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    May 2015
    13,195
    Quote Originally Posted by n240sxguy View Post
    Yeah, tell me about. I used to work with Excimer lasers (KrF and XeCl) and all halogen gasses had to be stored and used inside fully automated gas cabinets with double-walled stainless steel tubing going out to the equipment. There were also chemical gas sensors in the room that had to be tested monthly. When we changed cylinders out, the gas cabinet purged and sealed all the lines BUT we still had to wear SCBA equipment and be fully trained.
    I see the Pima Chemical trucks around here all the time with their chlorine and CO2 cylinders in the back. I drive 200ft behind them
    Matt
