Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: TurboCell Flow Switch - No power
    Jul 2010
    Longwood, FL
    151
    Yesterday I was weedwacking & my flow switch wire got tangled in my wacker.
    Now on the display I DO NOT have any LED's
    No power / No Generating
    What could be the cause & what will be solution !
    15,000 Plaster IG Pool
    AquaRite SWG, C1750 Catridge filter
    G3 Vaccum, T-100 Kit
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: TurboCell Flow Switch - No power
    Uh, not to be Captain Obvious here but didn't you shred your flow wire? I'm thinking you cut the wire.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Jul 2010
    Longwood, FL
    151
    Visibly nothing is damaged nor loose but you are right it might be damaged
    Jul 2015
    Bergen County, NJ
    113
    I'm not sure a break in your flow switch wire properly explains the NO Power LED. I would expect the Green Power LED to be ON and the Red NO FLOW LED to also be ON if your Flow sensor wire is damaged. Are you sure you didn't trip a breaker or damage the wires that supply power to the unit?
    53K Gallon Plaster in-ground with ALL Hayward equipment including Omnilogic Automation, Phantom Turbo Cleaner, SwimClear Cartridge Filter, Heater, Dual T-15 Salt cells. TF-100 Test Kit w/Speedstir.
    Jul 2010
    Longwood, FL
    151
    Thats what I thought and asked this question. Generating should be ON because CELL power wire is just fine..
    Also alll other wires are in distance and safe and no damage
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Just damaging the wire to the flow switch wouldn't do that. Start out by seeing if AC power is getting to the box.
    chiefwej
    Jul 2015
    Bergen County, NJ
    113
    If you have AC going to the box, then you should check the output of the transformer inside the box. A dead transformer will explain NO led's.
    Jul 2010
    Longwood, FL
    151
    How do I check transformer output ! I dont have any device !!
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    If both the AC power is there and the transformer is OK, then you have the dreaded (but common) failed input resistor.
    That's a $2.50 part but a little bit of a PITA fix.
    chiefwej
    Jul 2010
    Longwood, FL
    151
    Any video or pictuires how to fix it ?
    Jul 2015
    Bergen County, NJ
    113
    On YouTube lookup "Aquarite Hayward No Cell Power"
    Jul 2010
    Longwood, FL
    151
    Found it , what is the Digikey part number !
    Can you post all of the diagnostic readings?
    The part is as322r025 or sl322r025 depending on which board you have.
    Support the site
    Jul 2010
    Longwood, FL
    151
    Sure I will post all readings tomorrow
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    You better make sure that's your problem before ripping the box apart. This is the one I used.
    SL32 2R025 Ametherm | 570-1062-ND | DigiKey
    chiefwej
    Jul 2015
    Western NC
    115
    Quote Originally Posted by sunny8088 View Post
    No. Generating should be on if and only if the cell is generating. That is not going to happen if there is no detected flow. There are a few other conditions too, but they don't seem relevant in this case.
    I don't see why damaging the flow switch wire would cause anything else to fail.
    23,000 gallons IG gunite, pebble (I think)
    Hayward SP2610X15 1.5 HP Pump, Hayward sand filter
    Mineral Springs SWCG (it's actually Hayward/Goldline), Hayward Goldline T-CELL-15
    Polaris pool cleaner (with booster pump)
    TF-100, SpeedStir, K-1766 Taylor Salt Test, Lamotte Borate test strips
    Jul 2010
    Longwood, FL
    151
    No flow swith lights for 1 minute
    Generating light for 10 seconds
    My reading
    3.0
    28
    5.2 keeps on increasing
    0.00
    57P
    -0.00
    AL.0
    r 1.40
    Then on LED blank/off
    Jul 2015
    Bergen County, NJ
    113
    Sounds like your transformer is OK and you need to replace the inrush current limiter part.
    Jul 2010
    Longwood, FL
    151
    Yes I ordered from Digikey : SL32 2R025 Ametherm | 570-1062-ND | DigiKey
  20. Back To Top    #20
    Jul 2010
    Longwood, FL
    151
    Back in the business, replace digikey part & got power & generating LED
    Now the display starts with 3.0 instead of 3300 for salt level , any suggestions !
