Thread: Game adapters leaking
    Blacklisted's Avatar
    Sep 2013
    El Cajon CA
    126
    I just bought a new pump and the game adapters to adapt the stock intex hoses to the pump for now till I hard plumb everything. My pump directions say to hand tighten and then 1/2 turn. I did that and they are still leaking, I used the teflon tape that came with it so there is thread sealant. Do I need to crank the adapters tighter? How tight is everyone getting the adapters they install so they don't leak? I don't want to break anything and just trying to get some input before I crank them down more. Thanks in advance.
    Al
    Intex 15'x42" Metal Frame pool 4200 GAL with Intex SWG. TF-100 test kit. Our Pool Install Thread
    In Work! Master Spas Legend Series LSI 557 3-4 person Hot Tub, 230 GAL using bromine to sanitize it. Hot Tub Install Thread
    Jun 2015
    Mesa, AZ
    16
    Re: Game adapters leaking
    I would use tape and pipe dope.
    22' X 52" Intex Ultra Frame AGP 10,400 gallons
    Intex 3,000 GPH sand filter & Hayward thru-wall skimmer
    Taylor K-2006 test kit
    Sep 2013
    El Cajon CA
    126
    Quote Originally Posted by NinjaWorf View Post
    I did use teflon tape, I don't have any dope at the moment but might get some if I can't get it to stop leaking.
    titleistseemore's Avatar
    Jul 2014
    Lodi Ca
    189
    I used different Teflon tape then what came with the adaptors, I had to tighten a little more than 1/2 a turn
    Tim Jacobsen Lodi Ca.
    18'x48" Intex Ultra Frame (5700 Gallons)
    TF 100 Test Kit, Speedstir, & Sample Sizer. Liquidator Installed.
    Hayward C550 Cartridge Filter (55 Sq. Ft.), 1HP Powerflo LX Pump, Pool Rover Jr.
    http://www.troublefreepool.com/threa...uild-Questions
    Jun 2015
    Massillon, OH
    13
    I use rtv sealant and have had no leaks
