Thread: little bit of white vinegar a problem
    Jul 2012
    Whidbey Island, WA
    397
    Good morning
    Slate guys cleaning slate. Using some white vinegar to help dissolve crud. Trying very hard to wash it away from the pool and are succeeding but, a little goes in I am sure.
    Read about vinegar on TFP and seems is not good.
    But is a teeny amount a problem?
    Thank you.
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    JoyfulNoise's Avatar
    May 2015
    13,231
    Re: little bit of white vinegar a problem
    You'll be fine. It's not going to do much of anything to your pool water. See this post for a brief chemistry discussion.
    Matt
    Jul 2012
    Whidbey Island, WA
    397
    thank you
    I feel better
