Results 1 to 9 of 9
Thread: New pool light problem
    Jun 2015
    Rocklin Ca
    78
    My pool light keeps tripping the GFI. I just replaced my light bulb It went on for about 10 min the GFI tripped. So I pulled the fixture out today no moister at all in it. So I remove the bulb turned on the switch GFI tripped. If I disconnect the wires the other light (have 2 lights) stays on and other outlets stay hot. So I took a compressor blew out the fixture and were the cord enters thinking may water is getting in threw the cord , did not help . Now I have it sitting in the sun to maybe at the end of the day it will work. I’m thinking I need a new Fixture.
    I know the cord leaving the fixture has a splice in it . Now I assume the conduit has water in it. I wont go into detail how the splice was done I would be amazed if water got in, plus the light did function for a while I also tested the fixture it was reading 118VAC . so if the splice was bad the light would have never gone on .
    Now the other problem is the light had about a 12” of extra on it to change the light , that’s why there’s a splice. And to get the cord to pull threw the conduit was almost impossible So pulling a new cord threw for new fixture might be a real challenge.
    Any thoughts Ideas
    What is the Orange round sticky out of the resin ?
    In ground 20,000gal - pebble-tec - salt, Intelliflo pump, Sta-Rite filter 450 sq ft ,Hayward 6060 booster pump, non functioning Aqua Rite SWCG, TF 100 test kit.
    Jun 2015
    Wildomar, California
    423
    Re: New pool light problem
    I would automatically replace the light, the whole unit. Since water is able to travel far into.the light conduit, you are facing a serious health issue. Any splice in a pool light cord is dangerous.
    Jun 2015
    Rocklin Ca
    78
    So the fixture has been sitting in the sun for about 3 hours, So now the GFI dose not trip and reading a 118VAC at the fixture. So that confirms the splice is solid but also makes me suspect moisture is entering threw the cord. It was dry when I took it apart must be the cord. Any suggestions ?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by OldPoolMan View Post
    Still this. Not safe otherwise.
    Isolated Spa - 345 Gallons
    Jun 2015
    Rocklin Ca
    78
    There are “Submersible Wire Splice Kit” available pretty common. I think even Home Depot sells them. That is what copied. I used soldered joints staggered, then put a thin layer of silicone on the joint , then shrink tube , then Silicone with a longer piece of shrink tube , Did that on all 3 joints .Then put silicone on all off it then shrink tube over that lapping over the cable ends couple inches on each side , more silicone , longer piece of shrink tube lapping over the two cable ends another couple inches. So I think I’m good .
    Ukie's Avatar
    May 2012
    Export, PA
    83
    Replace JFI breaker then. It might be defective, and it's much easier to replace it than light fixture.
    Lagoon shape, 23,600 Gal, steel walls by International Swimming Pools, "ultra-seam" liner by Latham, Pentair 011018 IntelliFlo 3HP Variable Speed Pump, PentAir CCP420 filter, Heat Siphon Z575HP, PentAir IC40 SWG, 2 LED Lights (Pentair Intellibrite 5G, 110V). 4 x 1.5’’return lines, 2 x 2’’skimmer lines, 1.5’’ waterfall line. All plumbing is "TigerFlex" pipe, all lines plumbed individually. Deck: travertine glued over concrete.
    Jun 2015
    Rocklin Ca
    78
    I replaced the GFI about 3 months ago I redid the wiring in the panel box it was just unorganized mess. On the same subject I replaced all the GFI's in the house last year after drooping an extension cord in the pool and the GFI did not trip. They do where out.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    underwater splice kits are find for what they are intended for. But they dont work well if connected to GFCI.
    I guarantee ya, the splice is the root cause of the problem.
    Divin Dave,
    Jun 2015
    Rocklin Ca
    78
    Then why dose the light function with no problems at all when it's been out of the pool, after it's dried out? The splice is still submerged if theres water in the conduit ? It seems to me if you have underwater splice you would defiantly want a GFI.
