Results 1 to 14 of 14
Thread: Trap DE while backwashing?
    Aug 2013
    Hilton Head, SC
    133
    Is there a way to trap (catch, capture, collect) DE sand while backwashing? I don't want it to go into my storm water drain system or on my grass. Is it bad for the grass? I have St. Augustine.
    thanks,
    ed
    4k, IG, Gunnite, Jandy Valve, 1HP Haywood, 2" flow, single 2" line for skimming & vacuum, Pentair FNSP 36 DE w/125 GPM Multiport 50 PSI, TF-100 Test Kit, built 1991, Hilton Head, SC
    38,283
    Re: Trap DE while backwashing?
    There are pieces of equipment you can add after your filter in order to separate the DE out. Or just switch to cellulose fiber instead of DE end you can backwashed right into your grass.
    Jun 2011
    Long Beach, CA
    2,784
    I added a Hayward separator tank to my waste line, Pro-Grid DE Separation Tank | Filters | In Ground Pool Filters - Hayward Pool Products. It does a good job at collecting the DE maybe 99% of it or so.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Can you then reuse it? Or are the pores full of stuff? If the pores are full, then why worry about it going down drain or on lawn?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,494
    Where I live in the DFW area, the City requirement is that you must put your DE waste output into the sewage drain. Putting it in the storm drain is not allowed. The reason that I have a cartridge filter, on my new pool, is because the City would not allow a DE filter unless it was plumbed into the house waste drain system. My two other pools have DE filters, and I find that I don't backwash them much, if at all. I find it easier to just break the filter apart about twice a year and that seems to keep everything in check. When I break the filter down, I just hose the old DE right on the lawn. I've been doing this for several years and have seen no ill effects to the grass, both Bermuda and St. Augustine.
    domct203's Avatar
    Jun 2015
    CT
    3,583
    Quote Originally Posted by pabeader View Post
    Because pool DE is a carcinogen.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Weird.
    Jun 2015
    Wildomar, California
    423
    You need a separation tank to catch the DE. Inside it is a bag that catches the DE, removeable, and after cleaning, is reinstalled.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    I just did some googling on diatomaceous earth and I never realized how nasty it is...if it really is. I used to use it in my aquarium canister filters way back in my teen years and I sure don't recall any dire warnings or anything. I agree: Weird.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by domct203 View Post
    Dom
    i wonder if that is true everywhere or just California.
    Support the site
    It's not toxic like a poison. It's a health risk if breathed in over long periods where the lungs get clogged and damaged similar to asbestos damage.
    Support the site
    domct203's Avatar
    Jun 2015
    CT
    3,583
    Quote Originally Posted by tim5055 View Post
    I'm pretty sure it's a carcinogen everywhere
    I have a curious dog and would worry about long-term backwashing of DE where she might be sniffing around for years.
    Dom
    Dom - TFP Guide
    Jul 2015
    Woodbridge, VA
    18
    Because of the potential health risks of DE (as noted above), I switched over to cellulose about 5 years ago and have not had any issues. I use Fiber Clear.
    V/r,
    Bryan
    15K Gunite; Pentair FNS Plus 48 - DE, Pentair Superflo VS, Raypak 2100 heater, Stenner 45MHP10 /w 15 gallon tank, TF-100
    Jun 2014
    Rogers, AR
    424
    I switched to Ecoklean because of health and environmental concerns and I couldn't be happier. I see a noticeable difference in water clarity.
    16x32 IG rectangular 21,800k new vinyl liner 2014, Triton II TR 50 sand Filter, Pentair 3/4 hsp whisperflow pump, 3 returns, TF100 test kit w/speedstir. Maytronics s 300i robot.
