Thread: Need test kit
    Aug 2015
    Greenwood Lake , ny
    27
    Need test kit
    Can someone tell me which vendor will ship me a good test kit the Quickest? I live in upstate NY. My pool has had algae problem for a month. I've had pool for 12 years. always used pool store to help. They are out of business. Store next town over in business for years and are no help what so ever. Taking over myself!
    30,000 gal inground, vinyl, Hayward sand filter, 1 hp pump, Well water make up, Raypak heater w/bypass, TF100 testing kit.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Need test kit
    tftestkits.net, the TF-100. It's the best test kit for your money. They ship usually within a day, should be there in 2-3 business days with regular shipping.
    The owners of tftestkits.net are also site owners here, so you can get great support for the kit as well.
    Once you get it ordered, spend some time in Pool School and you'll be able to take control of your pool in no time. ABCs of Pool Water Chemistry
    Welcome to TFP!
    Also: if you order the XL option, which you will likely need if you are dealing with bad algae, that puts you over the $80 order and you get free shipping right now.
    Isolated Spa - 345 Gallons
    Donldson's Avatar
    NW Ohio
    2,921
    Re: Need test kit
    Welcome to TFP Oscar!
    With clearing up an algae problem I recommend the TF-100 from TFTestkits.net with the XL option. Alternately the k-2006 is a good kit but if you are dealing with algae then you may run out of reagents. These are the only two kits I recommend as they have the FAS-DPD chlorine test which is key to clearing and maintaining a clear pool following the TFPC methods taught here.
    If this is your first time here too I recommend you stop by the pool school and start getting an idea how we will help you get things cleared up. Here are a couple pages that would be a good start:
    Pool School - SLAM - Shock Level And Maintain
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Need test kit
    welcome, the TF100 and XL option are great.. I would also get the speed stir as it is worth its weight in gold the led light is perfect when testing after the sun goes down...
    Jun 2014
    Gulfport, MS
    67
    Re: Need test kit
    The TF100 or the Taylor K2006 test kits are the only kits that can test chlorine levels in excess of 5ppm. The TF100 (with the XL option if you currently have algae) is hands down the best bang for the buck. If, however, you decide to order the Taylor kit I would highly recommend the "C" option (Taylor K2006C). If you order the standard Taylor K2006 thinking you are achieving a cost savings, you aren't. If you currently have algae you would need to go ahead and order another bottle of R0871 and container of R0870 (at a cost of about 18 dollars) at the same time you order the K2006 as you are going to run out of those two reagents very quickly.
    Edit....
    I concur with cowboycasey on the Speedstir. It probably saved me from wrist surgery during my algae outbreak .
    17K gal, AG, 1.0HP pump, 300lb, 3.14 sqft, 62GPM sand filter, Pool Pilot Nano SWG, TF-100 Test Kit
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Need test kit
    What they all said, or in other words just order the TF-100 with XL option and if money is not tight get the speed stir see my signature for the link
