Results 1 to 8 of 8
Thread: Just getting started with TFP...
    Aug 2015
    Livermore, CA
    2
    I haven't yet had time to go through all the PoolSchool materials and I have a question about my PH.
    Just took readings and I have the below... PoolCalculator says ~180oz bleach to get to 9ppm (which I think is right given my CYA). We've run the pump quite a bit in the last couple of days.. would that aeration lead to the high pH? So I had been adding muriatic acid to reduce pH but I'm all out. Do Borax and Baking soda both work to raise pH (because I have both on hand).
    Recommendations on the pH level given my below numbers? Thanks!
    CYA ~100
    FC 4ppm
    pH 7.8
    TA 110
    38,245
    Re: Just getting started with TFP...
    Welcome to TFP!
    How does the water look?
    Really you should replace water to lower the CYA as a first step.
    Yes aeration raises pH, and your higher TA speeds up how fast it rises.
    Borax mainly raises pH. Baking soda mainly raises TA.
    Aug 2015
    Livermore, CA
    2
    Thanks jblizzle!
    The water looks beautiful. I can't really replace water more than what is evaporating as we are in a severe drought here in the SF East Bay. We're limited as to how much we can use. I've switched off the tablets and to liquid bleach for about about two months and already my CYA has gone from ~120 to ~100. My pH seems to continually go up and I have to always add muriatic acid. Given what you said, should I seek to lower my TA so the pH doesn't rise so quickly? And if so, how do I do that?
    Mar 2007
    San Rafael, CA USA
    12,082
    The Pool School has an article on how to Lower Total Alkalinity, but this just speeds up a process that would occur anyway over time as you add acid. So this won't save on how much acid you add to get the TA lower, but it has you add more in a shorter period of time to lower the TA faster after which you shouldn't need to add as much acid.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Welcome to TFP!
    Yes, lower TA will help reduce PH rise. Here is how, Pool School - Lower Total Alkalinity Aim for around 80 to start with.
    Keep your chlorine above minimum for your CYA, Chlorine CYA Chart
    More on Pool School - Recommended Pool Chemicals
    And maintaining your pool, Pool School - ABCs of Pool Water Chemistry
    38,245
    The CYA will not lower due to evaporation ... only the water evaporates. The main way to lower the CYA is by physically removing water and replacing it.
    You need to keep the FC above 7ppm at ALL times to try to prevent anything for starting to grow in the pool.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    rogodeter, I hear you loud and clear about our horrible drought; I'm just over the hills from you. Perhaps over time you can do several smaller water changes. However, it will take longer and use more water.
    One idea: could you use the pool water for landscape watering?
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    As stated above, you are lowering your pH each time you add muriatic acid. But you also state that you are adding water due to evaporation. Do you know the TA level of your fill water? Might be worth testing.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
