Results 1 to 11 of 11
Thread: 15 year old pool needs new equipment / Help me choose
    Aug 2015
    Lakeland, FL
    4
    Question 15 year old pool needs new equipment / Help me choose
    Hello,
    I am looking to replace most equipment for my 15 year old, 12K gallon pool. Our heater no longer works, the chlorinator leaks, and my pump is single speed and also leaking around the impeller area. After looking at the website poolmoz.com (Top 5 Pool Equipment 2015) and other research, I am considering the following configuration.
    UV - SpectraLight SL-500 1700
    Heater- Hayward HP50HA 1550
    Pump - EcoPump EP-4 776
    Salt - AutoPilot Digital Nano 757
    Pre-Filter - MultiCyclone Centrifugal Prefilter 341
    Current Cartridge Filter (<2 years old) 0
    TOTAL: 5124
    This is a big purchase to swallow. Given that my pool is 14 x 26, average depth of 4' (sport pool 3'-5'-3'), with an actual number of gallons of <12K, should I change any of these choices? I am wanting to make these purchases within the next two weeks, as my quarterly commission is coming. The fiber optic pool light needs to be replaced also, but that will have to wait.
    I have replaced the filter, pump and chlorinator once each over the 15 years and installed the heater 12 years ago, (which recently died). I will be installing all components.
    I look forward to your thoughts. Thank you for your help.
    Built in 2000, 26' x 14' Roman sport 3'-5'-3', 12000 gal IGP, Plaster, STA-RITE IntelliPro Variable Speed 1 HP Pump, Pentair CC90 cartridge filter, AquaCal Tropical 75 Heat Pump, Hayward AquaRite T-Cell 9 SWG,Caretaker 99 In-Floor Cleaning System
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: 15 year old pool needs new equipment / Help me choose
    The UV isn't really necessary and only works when the pump is running (unlike FC). Also, I would drop the pre-filter as it too is unnecessary and decreases the pump efficiency. Saves $2k
    Mark
    Jun 2014
    Gulfport, MS
    67
    For that matter, if the pump is only leaking around the impeller housing and the motor is still fine, that can be rebuilt very cheaply. That would save another $775 minus 25 bucks for the seal kit.
    17K gal, AG, 1.0HP pump, 300lb, 3.14 sqft, 62GPM sand filter, Pool Pilot Nano SWG, TF-100 Test Kit
    Donldson's Avatar
    NW Ohio
    2,896
    Agree with mas, the UV is certainly not worth $1700. Outdoor pools get enough UV from sunlight to burn off CC buildup and the chlorine will do the rest. Any chlorine savings you might get from the system (which typically is zero or worse, but I'm not getting in to that argument today) will be far less than the cost of the UV system.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Aug 2015
    Lakeland, FL
    4
    Thank you Mark. That sounds reasonable and echoes other posts and UV discussions. Do you have any suggestions regarding pump brand and size (I notice that your pump only a 1/2 HP for a larger pool)? Also, the SWG brand and heat pump brand? I appreciate the advice.
    Aug 2015
    Lakeland, FL
    4
    Scott, I appreciate the option, but I am hoping to achieve some power savings with a multi-speed or variable speed pump. (Additional info on the leaks, they are also coming from cracks in the pump housing.) Any suggestions on a brand and/or size? Thank you.
    I noticed that you have a Nano SWG. Do you recommend it?
    Donaldson, I appreciate your advice. I have decided to jettison the UV light and will enjoy the savings. Do you have any recommendations on the type/size/brand of pump, SWG & heat pump?
    Aug 2015
    Lakeland, FL
    4
    Mr. Donaldson, I appreciate your advice. I have decided to jettison the UV light and will enjoy the savings. Do you have any recommendations on the type/size/brand of pump, SWG & heat pump?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by Nico View Post
    You have an in-floor cleaning system which requires high HP and high energy use so a VS seems like a bit of a waste to me. I am actually surprised, you can run your cleaning system with just a 1 HP pump. What is the make/model?
    Also, how do you use your cleaning system (hrs/day)? Any run time without the cleaner.
    Mark
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    SWG I have been using a Hayward Aquarite T-15 for over ten years. If the whole thing blew up tomorrow, I would buy another just like it. It works really well, gives you adjustments in one percent increments without having to be connected to an automation system (unlike other brands). Seems pretty bullet proof (except a $2.50 part that seems to need replacing after several years). I got 7.5 years out of a cell that cost $400, so chlorine cost was less than $57 per year.
    If you are buying a new pump, do yourself a favor and spend the extra for a Variable Speed. I have a Pentair Intelliflow pump that has a fully programable timer built in. Mine is the 011018 which is a 3 hp. but it runs most of its time on 150 watts or less electricity. It cost a bit more up front, but the flexibility is worth it. I have different speeds set for cleaning, solar system, regular filtration and chlorination (SWG flow requirement), and one for quick clean. These pumps cost a bit more, but are worth it.
    I don't know much about heat pumps, but I do know you don't need UV or prefilter, put that money elsewhere, maybe the pump. I do have a leaf canister plumbed in before my pump, which I like.
    chiefwej
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Another vote for the 011018 Pentair VS pump. You'll gain a lot of flexibility with the ability to adjust pump speed. It seems especially appropriate for a SWG in that you can run it for a long time (if you need to) at a very slow speed and still save quite a bit in electricity. You might check if your local utility has any sort of rebate program on VS pool pumps. Here in California, there is one for $100 right now.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Jun 2014
    Gulfport, MS
    67
    I noticed that you have a Nano SWG. Do you recommend it?- - - Updated - - -
    I've only owned it for this season, but I have had zero issues with it thus far. Like the Hayward, it is adjustable in 1% increments. I did quite a bit of research when my other unit crapped out. I knew I didn't want another of that type, the Pool Pilot system seemed to be the best value. I ordered it on Friday and had it on Saturday. Granted, I'm only an hour and a half from the company I bought it from, but they got it right out which I appreciated.
    edit....
    On the pump issue, I'll leave that to more knowledgeable people that myself to advise you on. I'm running an underrated 3/4 hp pump that only costs me about 18 dollars a month to run so it would take a very long time for me to re-coop the cost on one of those fancy pumps. The heater I really have no idea on. I'm on the MS Gulf coast, my swim season is already 8-9 months long.
