Results 1 to 20 of 20
Thread: Hayward salt cell panel runs hot
    Jan 2015
    Phoenix, AZ
    638
    I may be getting the terminology wrong but the programming panel for our salt cell lights, filter... seems a bit hot to the touch, mainly on the right top of it. it's attached to the part of the house that is wood and the next door neighbor's house recently caught on fire (clean your air vents above your stoves, especially if you fry food!) so we're extra aware. It's a Hayward. Do other's panels run kinda hot to the touch? thanks!
    40' x 12' IG shotcrete (3 1/2' 5, 4'), Hayward variable spd pumpSP3400VSP, Paramount PV3 in-floor, venturi skimmer, 14,400 glns, Hayward Turbo salt cell T Cell-15, UV, Hayward DE filter, model DE4820, 2 Hayward Color Logic 320 LED color lights, Hayward P4 w puck. 2" line to in-floor valve (46'), deck mount canister parascoping fountain, leaf canister, Marbella, pebble. new build 6-24-15
    38,299
    Re: Hayward salt cell panel runs hot
    Mine gets warm. I think it is normal.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Inside the box on the top right of the circuit board is the input resistor. It's a black round disk about the size of a quarter. It gets very hot when the unit is operating. So it is very normal for the top right of the box to be hot to the touch. That resistor is also famous for failing. If and when it does, the good news is $2.50 in parts and 20 min with a soldering iron and it's fixed.
    chiefwej
    Jan 2015
    Phoenix, AZ
    638
    thanku! so, it's not dangerous to have mounted onto a block wall? does it get hot on the backside?
    Jul 2013
    Lelystad, The Netherlands
    60
    Not familiar with your type/brand. Mine has cooling vents on the outside so I assume it is normal. After all it's a big trafo.
    Perhaps you can put some spacers between the wall and the unit ?
    40000 liter in ground vinyl pool with SWG : http://www.troublefreepool.com/threa...he-Netherlands
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    It maybe hot to your hand but it's normal and shouldn't be a problem.
    BTW: If and when it does fail, you can buy the part or $2.50. The shipping cost more than the part. Order a few to be safe. You have to take the board out to work on it. The easy way to replace it is to snip the legs off the old one and solder the replacement to those. That way there is no soldering to do on the circuit board. It takes about 15 min. Leave the old legs as long as you can, so you can wrap them over the new ones legs and solder. Now you can print this out and keep it for reference.
    SL32 2R025 Ametherm | 570-1062-ND | DigiKey
    chiefwej
    Jan 2015
    Phoenix, AZ
    638
    thankyou for your help! good to know that it's an easy/cheap fix if breaks, too. is it something that we could mess up for us folk who rn't that handy?
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    It does take a bit of finesse to pull the circuit boards out an do the replacement. There are YouTube videos showing how it's done..
    chiefwej
    It's probably the transformer. If it's getting that hot, it's probably defective and should be replaced.
    Note: This is a Hayward automation box such as AquaLogic, ProLogic or AquaPlus.
    Support the site
    Ohm out transformer leads,
    blue & white: 2.0-2.9
    gray & violet: 2.0-2.9
    http://www.nuccibros.com/sec_0934drR...ng%20Guide.pdf
    Support the site
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    The easy way to replace the resistor is to snip the legs off the old one and solder the replacement to those. That way there is no soldering to do on the circuit board itself. It only takes about 15 min. Leave the old legs as long as you can, so you can wrap them over the new ones legs and solder. It makes it much easier and leaves the resistor standing away from the board in a vertical position when reinstalled. That moves the heat way from the board and makes for better cooling.
    chiefwej
    Jun 2015
    Ottawa/Ontario
    340
    Quote Originally Posted by chiefwej View Post
    Brilliant! The simplest of approaches are usually the most efficient and effective
    68,000litre, IG vinyl, LorentzPS 600 Solar Pump & 1/2 HP Tristar, Sandfilter, Aquarite T-15 SWG
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    It's not the resistor (aka thermistor or inrush current limiter). That applies to the AquaRite. This is not an AquaRite.
    Support the site
    Troubleshooting the ProLogic - YouTube
    Here is a video showing the inside of the box. The transformer is in the top right.
    Support the site
    Jun 2012
    western NY
    1,560
    Quote Originally Posted by outdoorsgal View Post
    Remember, hot to the touch could be a temp as low as 120degrees F . That may seem hot to you, but the combustion temp of wood is well north of 750degrees F. If it was truly getting hot enough to combustion, the unit will have failed long before that.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Actually at temperatures as low as 350-400 F pyrolysis can begin which will over time char wood and lower its ignition temperature. But that's still a very long way above the "hot to the touch" range.
    We see that often in construction where wood has been placed too close to a heat source like a fireplace. I've seen houses where a fireplace had been in use over a hundred years, have a fire in a wall next to the flue. We open the wall and find chared wood all along the run of the chimney. The ignition temprature finally got low enough that one good fire in the fireplace ignited some of it.
    (40 years as a Fire Fighter. That's actually the Chief in chiefwej)
    chiefwej
    Jan 2015
    Phoenix, AZ
    638
    thx so much! We have good warranties on stuff for now but I won't worry about it for now and saved this on a word document for when it comes time to change it. Glad to know the advice that it's prob fine for now comes from a fire chief!
    If the transformer is getting excessively hot, then it's causing the inside of the automation box to be hotter than necessary. That is going to shorten the life of everything else in the box.
    Now, how hot is too hot, is not well defined. Transformers do get warm. However, if it feels hot, I would consider getting it checked out.
    Support the site
    Jan 2015
    Phoenix, AZ
    638
    jamesW. thx. i emailed the pb. i needed to complain about the in-floor system not seeming to do it's job, anyway.
  20. Back To Top    #20
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    We have the same panel, etc. Ours runs hot too. I'll deal with it if it fails. It's been running fine (and hot) for three summers.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
